How to upgrade a 620 indoor dome light!
motavated
Got tired of the old flimsy 620 one and I had to find a good more modern replacement.
Get the rear dome light of a Honda passport or a Isuzu rodeo 93-97 model.
Looks like this one!
This is how it looks installed.
What you need to do is grind the rear part of the lamp so it could fit the hole like this.
Then just drill two new holes and install.
Not responsible if you mess yours up!
Next week how to fix a broken 620 glove box door.
  • Replies 20
Nah its cool. Is it this one?
I actually didnt like it. I dont know... I just dont like it. I saw it on pintos, grand markies, broncos and f150... Looks to big too. I didn't even try it out. But it could work.
Another one that could work is the land rover front dome light. Looks like this.
Its flush so it might not require cutting. Here is a good pic.
Also maybe the later ford bronco one?
Edited by Motavated
  • 10 months later...
I got the rear view mirror from a 90s? GM Monte or Lumina (whatever). It's the kind that attach to the glass. Looks better and has day/night and two map reading lamps with switches. Wider, only illuminates your lap and not the whole cab, and not in your eyes. Comes on when door opened too.
  • 1 month later...
i really need to do something about my dome light. and i dont know if i even have the wiring for a door switch. if not, how hard is it to install?? are there any other switches i could use that woudl work in the place of the factory style pop in ones??
  • 2 years later...
Hey now, this is a good post. We all know how those dome lights have always sucked.  That first one you showed from the Rodeo looks real good.  Most the time I like the darkness but when you need a little light, BAM!!!  Thanks................
  • 10 years later...
