1974datsun Posted October 25, 2009 Report Share Posted October 25, 2009 whats the easyest way to pull a broke off bolt out of the timing cover? would it be easyer to by a new cover Quote Link to comment
datzenmike Posted October 25, 2009 Report Share Posted October 25, 2009 Is it in the cover like the 10mm water pump bolts, or is it a 12mm through bolt into the block? Actually one of the 10mm pump bolts goes through into the front of the block too. Cover should come off to get at it. Is it leaking oil or water yet? Can it be left? Quote Link to comment
1974datsun Posted October 25, 2009 Author Report Share Posted October 25, 2009 (edited) Is it in the cover like the 10mm water pump bolts, or is it a 12mm through bolt into the block? Actually one of the 10mm pump bolts goes through into the front of the block too. Cover should come off to get at it. Is it leaking oil or water yet? Can it be left? the bolt doesnt go into the block, it holds the water pump in place. i cant tighten up the water pump all the way causing it leak Edited October 25, 2009 by 1974datsun Quote Link to comment
ggzilla Posted October 25, 2009 Report Share Posted October 25, 2009 If it is a bolt you can drill it out, using Easy-Out from Sears. It will be easier than swapping the timing cover. Quote Link to comment
datzenmike Posted October 25, 2009 Report Share Posted October 25, 2009 Almost impossible to drill the broken bolt out of an aluminum casting, on or off the car. Replacing the timing cover is just as much work plus finding/buying one. Nothing to loose here.... how about super cleaning both gasket surfaces and de-greasing with brake cleaner. Then a coat of Form-A-Gasket or Permatex gasket maker on both sides and let set. Add a new gasket and assemble. http://www.devcon.com/products/products.cfm?brandid=2&familyid=384 or maybe this one: http://www.devcon.com/products/products.cfm?brandid=2&familyid=386 I strongly do nor recommend the RTV silicon crap for a job like this. RTV is only good enough for chevy valve covers. Quote Link to comment
1974datsun Posted October 25, 2009 Author Report Share Posted October 25, 2009 Almost impossible to drill the broken bolt out of an aluminum casting, on or off the car. Replacing the timing cover is just as much work plus finding/buying one. Nothing to loose here.... how about super cleaning both gasket surfaces and de-greasing with brake cleaner. Then a coat of Form-A-Gasket or Permatex gasket maker on both sides and let set. Add a new gasket and assemble. http://www.devcon.com/products/products.cfm?brandid=2&familyid=384 or maybe this one: http://www.devcon.com/products/products.cfm?brandid=2&familyid=386 I strongly do nor recommend the RTV silicon crap for a job like this. RTV is only good enough for chevy valve covers. i see what your saying, but i have ocd. the job needs to be done right or it will annot the hell out of me Quote Link to comment
datzenmike Posted October 25, 2009 Report Share Posted October 25, 2009 Got cha... definitely replace the whole motor :D Quote Link to comment
1974datsun Posted October 25, 2009 Author Report Share Posted October 25, 2009 Got cha... definitely replace the whole motor :D i am SLOWLY ;D Quote Link to comment
MAG58 Posted October 25, 2009 Report Share Posted October 25, 2009 Bet bet is to drill out out and then heli-coil the hole. Quote Link to comment
moparvwfreak Posted October 28, 2009 Report Share Posted October 28, 2009 Bet bet is to drill out out and then heli-coil the hole. yup. Quote Link to comment
