dimedriver Posted October 19, 2009 Report Share Posted October 19, 2009 I have an L18 in my 74' 620. It cam with a fan bolted straight to the water pump pulley no clutch. I picked up a clutch and fan from the junk yard off of a Z car Thinking they were all the same. So I found that the Z car has the four bolts on the fan assembly spaced just a little wider. I was wondering if I could just pick up a new water pump for say a 280zx and swap out the old one? I don't think its bad but I also just got the truck. I was thinking of getting the Beck/Arnly one from rock Auto. BECK/ARNLEY Part # 1310416 I already have a pulley with the correct spacing left over from a Z. It also seems to be the same height. I know if I do get a pump I need to look for the cast vs. the crappy stamped impeller. Am I going to to run into spacing issues where the pully is now further forward or will it be the same? -dimedriver Quote Link to comment
dimedriver Posted October 20, 2009 Author Report Share Posted October 20, 2009 So, am I totally off my rocker? Or is this justing going to work? I would like to order my parts soon. -Avery Quote Link to comment
hang_510 Posted October 20, 2009 Report Share Posted October 20, 2009 ive seen different bolt spacing for fans for the L series, they should be identical. if the pulley matches, then the fan will need some filing to fit, all 4 holes need to be adjusted the same. get a cast pump if avail. Quote Link to comment
datsunaholic Posted October 20, 2009 Report Share Posted October 20, 2009 It's not going to work. The Z type water pump/clutch fan/fan assembly is going to be too long and hit the radiator. Plus the pulley spacing might be different. The '75-79 water pump with clutch might fit but it'll be close. The '75-79 620 had the core support moved forward a bit for clearance. But if you use that setup, you need the matching fan. They're all different. There's the no-clutch fan, the "flanged clutch" Z-car fan, the small-clutch truck fan, and the large-clutch "car" fan (with the small and large being usually misrepresented as A/C- non A/C water pumps). There's also a large-clutch truck fan with different offset from a NAPS-Z 720. Quote Link to comment
dimedriver Posted October 21, 2009 Author Report Share Posted October 21, 2009 Thanks, whats the take on the flexible bladed fans? Sounds like this would be a more straight forward fix to replace this sold plastic clutchless kludge thats on there now. Quote Link to comment
hang_510 Posted October 21, 2009 Report Share Posted October 21, 2009 i have a stock 4 blade plastic fan as it the only that fit. :lol: i like the flexi fans though, got one for the wagon. Quote Link to comment
Z-train Posted October 21, 2009 Report Share Posted October 21, 2009 It's not going to work. The Z type water pump/clutch fan/fan assembly is going to be too long and hit the radiator. Plus the pulley spacing might be different. The '75-79 water pump with clutch might fit but it'll be close. The '75-79 620 had the core support moved forward a bit for clearance. But if you use that setup, you need the matching fan. They're all different. There's the no-clutch fan, the "flanged clutch" Z-car fan, the small-clutch truck fan, and the large-clutch "car" fan (with the small and large being usually misrepresented as A/C- non A/C water pumps). There's also a large-clutch truck fan with different offset from a NAPS-Z 720. No "mis-representation" going on.The large clutch 620 fan(and you are right-the Z-car unit won't work as the pulley depth is wrong)is what is called for at the parts counter when FACTORY A/C is used.The small clutch was used on all non-A/C trucks including the ones with after-market A/C. I just went thru this song & dance last week. Quote Link to comment
datsunaholic Posted October 21, 2009 Report Share Posted October 21, 2009 I'd agree with you, Ztrain, except that I've owned a lot of trucks that had and didn't have factory AC. Every one had the small fan clutch, using the small-clutch fan bolt spacing. I suppose it's possible that somone bought the wrong water pump, but then they had to change the fan too. I guess that it's quite possible that in my travels I've just never actually seen a 620 with a large fan clutch. My '78-81 510s, which also are marked as no AC/factor AC being different all use the large-clutch fans. Quote Link to comment
datzenmike Posted October 21, 2009 Report Share Posted October 21, 2009 There's also a large-clutch truck fan with different offset from a NAPS-Z 720. Doug, I'm fairly sure that the NAPS clutch fan and integral fan will fit the L series with no offset problem. I'll check when I get home but the NAPS plastic fanbolt pattern is a larger diameter to match the larher diameter NAPS clutch unit. The NAPS pump itself also has a larger internal vane and deeper cavity to contain it. Looks the same on the outside as the 620 pump other than the fan. Quote Link to comment
datsunaholic Posted October 22, 2009 Report Share Posted October 22, 2009 Hmm, maybe, but I was having issues matching a Z24 engine with a '81 510. The '81 510 fan fit teh clutch, but it hit the Z24 crank pulley. One too many rows. The Z24 fan, was too close to the radiator. Quote Link to comment
Z-train Posted October 22, 2009 Report Share Posted October 22, 2009 1)620 non-A/C & dealer A/C- small clutch mated to pulley/waterpump.7 bladed fan. 2)620 factory A/C-large clutch(L-24 size)mated to pulley/waterpump.L-24 8 bladed fan will fit but not the factory shroud.Misses by about 50 mm. 3)L-24-seperate clutch/fan & pulley 1)Should be sufficient 2)What changed with the installation of the larger clutch/pump?Did the fan change or did they use the L-24 fan and change the shroud dimensions? 3) Not gonna work on a L-16,18,20b due to pulley depth & fan shroud issues. Quote Link to comment
