coolant leak/spray
smokeybear
  • Replies 6
Cracked L-series blocks (cracked from overheating, not from freezing) usually don't leak externally, but a blown head gasket will. Probably a warped head to go along with it if it's spraying, though I've seen where it LOOKED like a head gasket but was just a pinhole leak in a hose that happened to be deflected right at the gasket.
  • 1 month later...
KC1, mine blew two weekends ago. Pass side #4, gasket split from the cylinder through the water jacket and on out through the side beside the heater hose. No warning and no reason, 300,000 Km and never touched the motor till now. Wierd eh?
