BRE_dAtSuN Posted October 17, 2009 Report Share Posted October 17, 2009 i recently finished my rebuild... l20b, nismo lightened connecting rods 87mm flattop pistons stock crank u67 head ported, 3 side polish, port matched intake and exhaust isky dual titanium valve springs webcamshafts 510 lift cam 266 duration steel cam towers oversized valves portmatched mikuni manifold dual s5 mikuni 44's rebuilt and tuned by rebello racing 79 200sx electronic distributor taylor wires, msd 6al box 200sx 5 speed 9 pound aluminum flywheel twin disc stage 2 clutch clutch pack type subaru lsd with 4.11 gears still breaking it in any suggestions on my next move? im already thinking its not enough power though =( Quote Link to comment
SHADY280 Posted October 17, 2009 Report Share Posted October 17, 2009 if you have done your initial break in, 2000 rpm for 15 minutes, did you change the oil and filter. other than that, give it a few thousand miles and lay hard on the loud pedal. make sure your timing is stock for the break in and then advance it to 36 total for the rest of its life. have fun, if you want more, turbo or s/c. ill take that "crappy" engine off your hands for free, you can keep the head tho. shoulda got a 219 sss. Quote Link to comment
DISLEXICDIME Posted October 17, 2009 Report Share Posted October 17, 2009 why did you go with the u67? Quote Link to comment
datzenmike Posted October 17, 2009 Report Share Posted October 17, 2009 It's an L20B head, with large valves, ports and the L1618 stock exhaust manifold matches the U-67's square ports. Quote Link to comment
ggzilla Posted October 17, 2009 Report Share Posted October 17, 2009 Question of HP? I estimate it will output 150 HP. Quote Link to comment
DISLEXICDIME Posted October 18, 2009 Report Share Posted October 18, 2009 It's an L20B head, with large valves, ports and the L1618 stock exhaust manifold matches the U-67's square ports. but wouldn't a w53 have worked better Quote Link to comment
dat u racing Posted October 18, 2009 Report Share Posted October 18, 2009 the head is good just drop it on a z-24 block Quote Link to comment
hang_510 Posted October 19, 2009 Report Share Posted October 19, 2009 ~135 rwhp im already thinking its not enough power though =( of course! money well spent though :D the diff in CC between heads could push the CR past using pump gas. part of the reason i chose it also. im excpecting similiar numbers on my LZ22 if you have a dyno day set in the future, id check mine too! Quote Link to comment
