SpooF Posted October 14, 2009 Report Share Posted October 14, 2009 whats the fastest way to remove the rear spring do i have to remove all four bolts on the back side of the hub from the driveshaft?. Quote Link to comment
DISLEXICDIME Posted October 14, 2009 Report Share Posted October 14, 2009 shock bolt and the dog leg bolt's becarefull dont let the trailing arm go to far down or you will snap the brake line. assuming this is on a pl510 sedan. Quote Link to comment
SpooF Posted October 14, 2009 Author Report Share Posted October 14, 2009 (edited) 2 dr ok thanks dog leg you mean the one hold the trailin arm? Edited October 14, 2009 by SpooF Quote Link to comment
SpooF Posted October 14, 2009 Author Report Share Posted October 14, 2009 anyone Quote Link to comment
murderwagon Posted November 6, 2009 Report Share Posted November 6, 2009 BUT THEY ARE INDI no leaf Quote Link to comment
BJW's FiveTen's Posted November 14, 2009 Report Share Posted November 14, 2009 Just undo the shock mount, make sure your head is out of the way. Pull shock off and spring should remove itself from the car. And be careful the brake line does not get damaged, I unbolt the t from the bottom of the car so there is no strain on the lines. Just be careful, those springs have a lot of energy stored in them when they are released. :D Quote Link to comment
