Old SU carbs
Just Joel
I was poking around the local pick n pull and came a crossed a 66 or 67 510 wagon and it just so happened to have a set of su side draft carbs bolted to the head. Would these potentially bolt up to my 71 L16? What kind of rebuild kits are available? What would be a decent price if I were to buy them?
Thanks
Joel
  • Replies 7
It depends on what kind of car it was at the yard. If it was a PL510 then yes. The carbs, (the intake manifold really) will bolt to your L-16, provided that it is the original L series engine. The 411 came with a different engine, the manifold from that engine wont bolt up to your L-16. Of course you could always buy the carbs and find a manifold for your car later. Maybe youll get lucky and get some 38mm SSS carbs.
