Datzoon521 Posted October 1, 2009 Report Share Posted October 1, 2009 i bought an 80 510 wgn with a z20s W/automatic.They have a 4 plug lead cap on dist.,thus nothing going to ex side of motor.will a 4 lead cap fit on a 8 plug dist.,or have they put an L series dist. in my z 20s motor?thanks for looking...>:} Quote Link to comment
datsunaholic Posted October 1, 2009 Report Share Posted October 1, 2009 A 1980 non-california Z20 came stock with the 4-plug distributor. Does it have unconnected spark plugs on the exhaust side? If so, I'd suspect the HEAD got changed, as 1980, non-california Z20s only had the 4 plugs. The 4 and 8 plug distributors are completely different. The 8-plug one is massive. Quote Link to comment
Datzoon521 Posted October 1, 2009 Author Report Share Posted October 1, 2009 Its not the stock motor,(jy replacement)and yes non used plugs on ex. side.so they put an l series dist.in it im guessing(Idiots everywhere) Quote Link to comment
datsunaholic Posted October 1, 2009 Report Share Posted October 1, 2009 (edited) L-series dist wouldn't fit, bases are different. They used the original 1980 dist because your car doesn't have the wiring for the 8-plug setup (8-plug uses 2 coils and 2 sets of trigger wires). Edited October 1, 2009 by datsunaholic Quote Link to comment
Datzoon521 Posted October 1, 2009 Author Report Share Posted October 1, 2009 Thats just super,have any sugestions other than changing head? p.s.thanks for helping me out...>:} Quote Link to comment
datsunaholic Posted October 1, 2009 Report Share Posted October 1, 2009 I suppose you could get blanks to fill the unused plug holes. It's not really effecting anything having "dead" plugs in the exhaust side, though you need to set the timing per the 1980 specs and not the '81 specs if running only 4 plugs (the ignition timing is different). Quote Link to comment
datzenmike Posted October 2, 2009 Report Share Posted October 2, 2009 Just run it the way it is. Besides all '80 California Z engines, these all have the 8 plug dizzy and coils: '81 A10, '81-'83 200sx, '81-'82.5 720. Keep an eye out for one of these dizzys and the matching coils for cheap and swap in at a later date. Quote Link to comment
Datzoon521 Posted October 2, 2009 Author Report Share Posted October 2, 2009 Thank you guys for all your help.This forum is kick azz!!!Can you use an 8 plug dizzy w/matching coils from any of the z22 or z24 motors?...>:} Quote Link to comment
datzenmike Posted October 2, 2009 Report Share Posted October 2, 2009 Definitely the Z20 and Z22, probably the Z24 but not positive on this. Quote Link to comment
