77 620 for Sale $700 in CA
1977 Datsun 620 4 speed manual transmission 2.0 liter L20B with a W58 intake manifold and Rebuilt Hitachi DCH 340 stock air cleaner setup and all emission components. Carb will need to be adjusted for it to pass smog inspection. New headlights and switch , I upgraded the alternator from a 35 amp externally regulated unit to a 60 amp internally regulated unit. I have installed the lower water outlet from a 280zx to clear the altenator . The thermostat and all the hoses and belts have been replaced. I installed a new starter , battery , ignition wires , coil ,distributor stator , cap , rotor, plugs and the transistorized electronic ignition box. Lowered with 2" blocks in the rear and torsion bar cranked down in the front. New 185 60R14 tires in front and practically new tires in the back. Interior floor boards were rusted but have been temporarily patched and painted to protect from further rust. The dash had been removed for a swap and to check the wiring and repair any electrical issues. The dash pad and instrument cluster would need to be replaced to be put back to stock. The truck has front disc brakes stock and stock 6 lug wheels . Emergency brake needs to be adjusted. Have over 2,000 total invested in it allready and can't spend any more money on it. take over and finish this project. 109,000 miles on it I did a compression check on it 160psi on all 4 cylinders.
$700
Registration paid until Nov of this year. Truck would need to be towed PM me and we might be able to work something out.
  • Replies 0
