Radiator for a ka24de???
  • Replies 91
In reality, the CXRacing radiator is silly wide. Here is how wide it is. I have opened up my radiator opening 1.5" on either side and Im still not even close to getting to the end tanks.
How it looks through the core support on a 510:
And from inside the bay, notice how close it is to the headlights...
  • 1 year later...
I just wanted to post this here for future searches, Dayco #71601 lower rad Jose works perfect with the 97 Jetta rad. As Creepycruisers method of using old radiator hose as a reducer it works perfectly. I'll post a picture of fitment later
  • 1 year later...
AFCO 80104n -
https://www.summitracing.com/parts/afc-80104n
You can see the hose numbers I used as well  (Both needed to be trimmed down)- both the hoses I used do require a reducer on the engine side - each one needed to be reduced by 1/4" if I remember correctly - I also ended up going with an inline thermostat as well since I plugged the heater core outlet and had temp issues.
36145018193_83684b1c6c_z.jpgUntitled by Devon Mitchell, on Flickr
36765746256_406af887e3_z.jpgUntitled by Devon Mitchell, on Flickr
36144687873_a4f5f3d833_z.jpgUntitled by Devon Mitchell, on Flickr
  • Like 3
