moparvwfreak Posted September 29, 2009 Report Share Posted September 29, 2009 i am putting an L20 in my 620 and just want to confirm what i can use off my L16. intake and exhaust oil pump distributor (might be using the HEI mod and going EI) clutch release sleeve i want to run the PCV system properly. and i dont want to fight with the L20 exhaust manifold anymore. it keeps falling apart. thanks guys!!1 Quote Link to comment
datzenmike Posted September 30, 2009 Report Share Posted September 30, 2009 If the L20B is from a truck the oil pan should clear but as with the 521, you may have to use the L16 oil pan, so be prepared for this swap. If from a car you could probably use the L16 pan and pick-up. If the L20B is a '78-'80 use that intake. If it's a '75-'77 try to find a later intake as the L16 intake has smaller runners. You can use the square port L16 exhaust manifold on the L20B head, even if it's the round port W58 from '78 up. The L20B sits 3/4" taller at the head so the exhaust down pipe will also sit 3/4" higher going under the cab. While all L series oil pumps will interchange, even the diesel, find one from a KA24E 240sx, Z24i, KA24E or DE from a D-21 Hardbody. These all use the high output pump with larger rotors for more volume at lower revs. The PCV system connects to the intake so exhaust manifold is not an issue. Definitely get and use the L20B EI dizzy. (remote or matchbox) Quote Link to comment
sdsurf Posted September 30, 2009 Report Share Posted September 30, 2009 ditto, got to run the 521 oil pan Quote Link to comment
datzenmike Posted September 30, 2009 Report Share Posted September 30, 2009 This is an L16 620 switching to an L20B motor. If this L20B is from a newer 620 it's possible it will fit, pan and all, into the older 620. Just saying that if not, the L16 pan should work. Quote Link to comment
MAG58 Posted September 30, 2009 Report Share Posted September 30, 2009 While all L series oil pumps will interchange, even the diesel, find one from a KA24E 240sx, Z24i, KA24E or DE from a D-21 Hardbody. These all use the high output pump with larger rotors for more volume at lower revs. The DE pump will not work, as it's a gerotor driven off the crank (ala RB, LSx, etc.) Quote Link to comment
moparvwfreak Posted September 30, 2009 Author Report Share Posted September 30, 2009 If the L20B is from a truck the oil pan should clear but as with the 521, you may have to use the L16 oil pan, so be prepared for this swap. If from a car you could probably use the L16 pan and pick-up. If the L20B is a '78-'80 use that intake. If it's a '75-'77 try to find a later intake as the L16 intake has smaller runners. You can use the square port L16 exhaust manifold on the L20B head, even if it's the round port W58 from '78 up. The L20B sits 3/4" taller at the head so the exhaust down pipe will also sit 3/4" higher going under the cab. While all L series oil pumps will interchange, even the diesel, find one from a KA24E 240sx, Z24i, KA24E or DE from a D-21 Hardbody. These all use the high output pump with larger rotors for more volume at lower revs. The PCV system connects to the intake so exhaust manifold is not an issue. Definitely get and use the L20B EI dizzy. (remote or matchbox) ok. a little clarity. the motor is coming out of my 78 KC. so everything will bolt over no problem. i really wanted to use my L16 intake as it actually has the PCV system intact where as my L20 manifold doesn't. and witht he weber carb the PCV plate wont fit. so it looks like i am SOL on using my 16 intake. as for the oil pump, i KNOW the one in my 16 was good. the one in my 20 is not as hot. it takes FOREVER to build pressure but maintains it once its up. i know about the KA pumps but this is still a budget build. hence the interchange questions. as for the exhaust, i dont care if it sits higher. it was hanging low anyway so thats ok. as long as i can get it to bolt up i dont care. dizzy, i was just wondering about it since i still ahve to get the HEI module so i can wire it up (remote system). but IF i had to, i could run the points to get it going. Quote Link to comment
datzenmike Posted September 30, 2009 Report Share Posted September 30, 2009 The DE pump will not work, as it's a gerotor driven off the crank (ala RB, LSx, etc.) While all L series oil pumps will interchange, even the diesel, find one from a KA24E 240sx, Z24i, KA24E or DE from a D-21 Hardbody. These all use the high output pump with larger rotors for more volume at lower revs. The KA24DE from the '98-'01 D-21 will work. I agree it's the KA24DE crank driven eccentric pump in the 240sx that won't. Here's a picture of a truck KA24DE motor: http://i138.photobucket.com/albums/q251/datzenmike/L%20Z%20Heads%20and%20Motors/motorKA24DE1999frontier3.jpg[/img]"] I call them D21 but maybe Frontier would be more accurate? Quote Link to comment
yello620 Posted September 30, 2009 Report Share Posted September 30, 2009 as for the exhaust, i dont care if it sits higher. it was hanging low anyway so thats ok. as long as i can get it to bolt up i dont care. I found that the L16 down pipe would not bolt up because of the height difference, The side of the pipe interfered with the L20 block.:( Just meant that i had to hammer the pipe a little to get it to clear so i could get it to the exhaust shop. Quote Link to comment
moparvwfreak Posted September 30, 2009 Author Report Share Posted September 30, 2009 wonderful. something else that doesn't work right. Quote Link to comment
moparvwfreak Posted October 21, 2009 Author Report Share Posted October 21, 2009 motors almost in but the mounts aren't lining up. 78 L20B out of a 620 going into a 620 originally an L16. also it looks as though it sits to high. should i use the L16 mounts and call it a day orshould i fight with it to keep the L20 mounts???? Quote Link to comment
datzenmike Posted October 21, 2009 Report Share Posted October 21, 2009 Hell, try the L16 mounts. Quote Link to comment
yello620 Posted October 21, 2009 Report Share Posted October 21, 2009 Try the L16 mounts, but also remember that the L20 is a taller motor than the L16. It is going to look a little taller. Quote Link to comment
moparvwfreak Posted October 21, 2009 Author Report Share Posted October 21, 2009 alright. i will try the L16 mounts in the morning.hopefully i can get it going soon. Quote Link to comment
