aftermarket oil temp gauge?
zed
Where do I put the temperature probe / sender for an aftermarket oil temp gauge - on my L18? I could drill and tap the oil drain plug - but that seems a bit crude. I'm already using the OEM oil pressure sender hole near the oil filter for a VDO sender and the idiot light switch (via a brass T-piece).
  • Replies 2
