kiznook Posted October 9, 2007 Report Share Posted October 9, 2007 found this neat calculator/simulator while doing some research figured it could be of some use to everyone.http://www.rims-n-tires.com/rt_specs.jsp (website gone!) Edited by Bleach: https://tiresize.com/calculator/ 1 Quote Link to comment
Bleach Posted October 9, 2007 Report Share Posted October 9, 2007 thank you. That is good infoI've used the Miata TireSize Calculator quite often.http://www.miata.net/garage/tirecalc.htmlIts good for comparing tires but I like how I can see the tread width in inches on the link you posted. (Miata calculator is dead as well. Check out the link above in the first post) 1 Quote Link to comment
Icehouse Posted October 9, 2007 Report Share Posted October 9, 2007 That is a bad ass wheel calculator! I tried to stretch the tire, it didn't work though... Quote Link to comment
kiznook Posted October 10, 2007 Author Report Share Posted October 10, 2007 I was suffering from the same trouble as you Bleach, That and that fawking miata page takes forever to load (might be my machine) then I did the abnormal clicking of links lower on the Google search page. Doesn't everyone usually give up after finding what theyre looking for on the first couple of hits....Sometimes you can find something BETTER!! Quote Link to comment
shane_lxi Posted October 23, 2007 Report Share Posted October 23, 2007 found this neat calculator/simulator while doing some research figured it could be of some use to everyone. http://www.rims-n-tires.com/rt_specs.jsp Sweet :D! Quote Link to comment
gen4maxima536 Posted March 23, 2008 Report Share Posted March 23, 2008 here is another one that i usually use http://www.1010tires.com/tiresizecalculator.asp Quote Link to comment
RandyinRenton Posted October 25, 2008 Report Share Posted October 25, 2008 this may be an odd question, but does anybody know what the most common rim diameter is? I ask because it would seem like that would be the size with the most selection and lowest price. It used to be a 15" rim, but now there are so many rigs that come stock with 16's and 17's... it's hard to tell. Quote Link to comment
bonvo Posted August 25, 2010 Report Share Posted August 25, 2010 i like this one the most http://www.willtheyfit.com/ Quote Link to comment
Bears510 Posted August 26, 2010 Report Share Posted August 26, 2010 this may be an odd question, but does anybody know what the most common rim diameter is? I ask because it would seem like that would be the size with the most selection and lowest price. It used to be a 15" rim, but now there are so many rigs that come stock with 16's and 17's... it's hard to tell. what I have seen seem to be more common in 15" 17" 18" and 20" and those also seem to have the widest range of tires avail for them as well.... Quote Link to comment
jastrunk97 Posted October 31, 2011 Report Share Posted October 31, 2011 <b>SWEET!!</b> thanks Quote Link to comment
mikeanike99 Posted May 7, 2014 Report Share Posted May 7, 2014 i like this one the most http://www.willtheyfit.com/ That actually helped :thumbup: 1 Quote Link to comment
mmitchell57 Posted May 23, 2014 Report Share Posted May 23, 2014 Best calculator I've ever seen! Quote Link to comment
Ron1200 Posted July 17, 2015 Report Share Posted July 17, 2015 I ran across this one in my web travels. Loads fast. No ads. Lots of info, including a speedo difference chart. Unlike most sites, it will allow decimal wheel sizes, perfect if you run 390mm wheels. ☺ https://www.tacomaworld.com/tirecalc 1 Quote Link to comment
rosso Posted July 28, 2018 Report Share Posted July 28, 2018 (edited) I know it is an old thread, but here is the most bestest tire calculator I have ever found. http://www.rimsntires.com/specspro.jsp 2/24/23 EDIT: Site no longer exists. 😞 Edited February 24, 2023 by rosso 1 Quote Link to comment
datzenmike Posted July 29, 2018 Report Share Posted July 29, 2018 I wish more would use it instead of... "I just bought some 8" wide 17" rims with +10 offset... will they fit my 510 with my 225/60R17 tires I bought?" Bad enough asking but asking after you already bought the tires and rims??? Really? ? (these emoji suck) 1 Quote Link to comment
