How do you install a aftermarket temp guage? help?
motavated
I have one like this.
And I want to install it while keeping the original temp sender. I want two gauges to be sure my truck runs ok. The thing is the lower t housing has two holes. One for the original temp sender and another smaller hole. The thing is that the sensor of the aftermarket temp gauge does not fit into that smaller hole. Is there anything I could do? Any ideas? Thanks!
One hole is for the stock sender, the other is open and heads towards the intake, the other smaller hole has a sensor but the hole is to small... HelP? Guy?
  • Replies 29
I am using this top housing from a Mazda 323 from the yard.
I just looked around and I just found it. They had a z there so I tried it on and it sort if fits. Needs some trimming but not bad! Will use this guys. Thanks!
"this is actualy a pic of a miata cover" it also seems that it might work...
Edited by Motavated
i've done this.i have my original oil and water sending units with aftermarkets also. most people just unhook the originals. i did as dholic said and put the l20b housing on and took the vacuum switch out. i bought my adapter from wolfsco "williams oil filter service company". i have the receipt somewhere with the part number. i'll look for it now.
Nevermind.I just saw the 280 degree thing and thought oil/trans temp guage.Because if your coolant temp gets north of 240-you're screwed.But then i looked and saw that all three guages go to 280 degrees-which makes no sense.
I was thinking the temp guage should top out 240ish and have smaller graduations.:mellow:
There is another solution.Take ANY top T-stat housing and weld in the fitting for the temp sending unit.That way it gets the temp right at the T-stat but the probe doesn't hit the bottom of the stat itself.
I'll see if i can get a pic tomorrow.
Edited by Z-train
The trouble is different thread types. I have a 78 620 and it has two ports, but my oem temp sensor is in the lower frontwards facing port and the driver side facing port has a temp activated vacum switch (for smog stuff)
I took that out and planned to screw in my temp probe for the aftermarket gauge and noticed it screwed in but was loose and wouldn't seal. After visiting the home depot I I.D. the threads. the OEM housing is BSPT threads and the after market threads are NTP.
So if you are using a L20B housing then you are looking for 3/8 bspt (british standard pipe thread) male to 3/8ntp female adapter. I know this because I just finished doing the same thing.
newguy
Edited by newguy
The thermostat housing from any fuel injected 280z should work. The old maxima/810 that had the L28 in it would also have the same housing. I think it had three or four ports on it. Its easy to identify, it has three bolts holding the hose outlet on.
-Avery
In the maxima/810 (80-83) was either a ld28 or a l24e, no l28s.
The 280z thermostat housing isn't held on with 3 bolts. The 280zx and maxima/810 are though. They all have 4 ports.
So if you nab a 280z housing you can still use the 2 bolt hose outlet you perdied up.
Edited by 72240z
Why did you switch the sensors around in the thermistate housing? kinda curious.:confused:
looks like you put the temp probe (aftermarket gauge) in the front port and the OEM temp sensor in the other.
Well that worked out for you. Looks good.
I'd like to just throw out that you should solder not use butt connectors :-X. How many car's I've had to break my balls diagnosing because the bay was full of butt connectors, sigh.......
Edited by 72240z
yes i think the reason was my tripple guage kit cam with one adapter that only fit in that hole. the other adapter i bought was a s/w 16x1.5 part number 82573
The after market gauge is placed under the thermostat and will read at 180 deg since I have a 180 thermostat. But until the thermostat opens, the stock datsun gauge will stay silent and read COLD, right? If the after market gauge starts reading 190 or higher, and my stock one still reads zero or cold. My thermostat is probably dead and I have to pull over quickly... I want to see at all times how hot is my engine in degrees. The stock one just says hot or cold. Get my point?
if your after market gauge starts to read over 190 your stock should in the red. i tend to get thermostat's that like to stick when new for some reason. mine used to go up to 220 once in a while the would plumit down fast to normal operating temp. somethings got to give when that happens either a head gasket or the thermostat. i've always got lucky and the stat becomes unstuck. ever since i replaced my radiator and water pump i noticed my engine runs hotter. i noticed some water pumps have bigger l shaped fins. whats up with that.
dont know about a 620 but on a 521 the spot between hot and cold is normal temp. there is also an adjustment on the back of the gauge to dial it in.
Wow! I didn't know that!
My question is which water pump is the best?!?!?!
Some have bent metal blades and others are made of iron?
Also which design is better from the iron ones???
That would be nice to know... Thanks!
