1974datsun Posted October 23, 2009 Author Report Share Posted October 23, 2009 my motor stopped running. i wonder what i did wrong. its getting spark, fuel, and the valve clearences are correct. im thinking piston rings....... Quote Link to comment
banzai510(hainz) Posted October 23, 2009 Report Share Posted October 23, 2009 It just stopped? throw us a bone here. wire fell of the ignition/ballast resisitor? you have spark so I say its good. does it run in start then doesn when key goes to on? you have to be specific. you say fuel so I assume filter and carb is not plugged. or is there a idle cut off seliniod and when you let off the gas it dies but if you pump the gas it stays running? recheack the intake and carb bolts. re cheack TDC and location on the dizzy. recheack the valve clearance. ck the spark plugs. did you gap the rings? even if you didnt car should still fire off one of the other cylinders enoug to barely to keep it running. lash pads still on rockers and ddint fall off? Quote Link to comment
1974datsun Posted October 23, 2009 Author Report Share Posted October 23, 2009 It just stopped? throw us a bone here. wire fell of the ignition/ballast resisitor? you have spark so I say its good. does it run in start then doesn when key goes to on? you have to be specific. you say fuel so I assume filter and carb is not plugged. or is there a idle cut off seliniod and when you let off the gas it dies but if you pump the gas it stays running? recheack the intake and carb bolts. re cheack TDC and location on the dizzy. recheack the valve clearance. ck the spark plugs. did you gap the rings? even if you didnt car should still fire off one of the other cylinders enoug to barely to keep it running. lash pads still on rockers and ddint fall off? gap the rings? Quote Link to comment
HRH Posted October 23, 2009 Report Share Posted October 23, 2009 Did you break a drive spindle? Unlikely, but just stopped running with fuel and spark does seem odd. Is the bowl on the carb full? Quote Link to comment
1974datsun Posted October 23, 2009 Author Report Share Posted October 23, 2009 Did you break a drive spindle? Unlikely, but just stopped running with fuel and spark does seem odd. Is the bowl on the carb full? the bowl is full Quote Link to comment
freaky510 Posted October 23, 2009 Report Share Posted October 23, 2009 have you checked to make sure you plug is sparking, not just your wire:confused: what carb do you have?? also i have broke a cam on the inside of the first journal s/p?? Quote Link to comment
