yello620 Posted September 29, 2009 Report Share Posted September 29, 2009 Awesome writeup!!! And to think that I was trying to throw away a brand new clutch type water pumps away!!!!!!!!!!!! Yep Mike the S12 is an awesome temp sensor! remember red bad white good. The red switches at 205ish the white at 185ish. Jeff, can you clarify this? Are there two different S12 sensors? And they are color coded? Pretty sure this is what you mean.:D Or are you talking that they are a two stage switch and each of the two wires are switched at different temps? 1 Quote Link to comment
bonvo Posted September 30, 2009 Report Share Posted September 30, 2009 interesting now the real question is there a ld28 waterpump like this or does it not have the clutch or are both avalable i was looking into the ld28 waterpump mod for the bigger fins 1 Quote Link to comment
Charlie69 Posted October 1, 2009 Author Report Share Posted October 1, 2009 All the water pumps I have checked online at rock auto do not have the clutch on for the 280, 260, & 240z, zx, & 2+2. Datzenmike or steriod I believe know of a certain model that does have the clutch on it but I believe that you have to change crank pulley and alternator spacing to line up the belt. Quote Link to comment
oldsklminitrk Posted November 6, 2009 Report Share Posted November 6, 2009 Not to thread jack but I found a 80 720 and yanked off the water pump and front pulley that bolts on.Then crossed the part numbers and got one from Orielly it was 19.99 and the pulley was 10.00 bucks a junkyard.No cutting all the pulleys lined up and it fell into place.Ill post pics tonight. 1 Quote Link to comment
Charlie69 Posted November 7, 2009 Author Report Share Posted November 7, 2009 Cool, post up some pictures, measurements, part #'s, and description of other vehicles that this crosses to. Was this off a truck with standard transmission and no AC? All of the clutchless water pumps I came up with had longer shafts with deeper pullies. That is what this thread is for INFO, you are not thread jacking in my opinion. Thanks for the post waiting for more info. Quote Link to comment
really_drunk Posted June 22, 2012 Report Share Posted June 22, 2012 Great write up.. Was struggling to find room for an electric fan to fit.. I have a champion aluminum radiator an only have 2" to spare so any room will help I'll be trying this soon.. Just 1 ?. The pulley is bolted on or just pressed fit? 1 Quote Link to comment
datzenmike Posted June 22, 2012 Report Share Posted June 22, 2012 Clutch fan pulleys are pressed on and cannot be separated or the clutch removed from the pump. 2 Quote Link to comment
really_drunk Posted June 22, 2012 Report Share Posted June 22, 2012 Thx Mike just ordered the part.. Now lookin for a electric fan to accompany... Stuck between 1 big1 or 2.. Would be interested to hear what others have used!! 1 Quote Link to comment
really_drunk Posted June 22, 2012 Report Share Posted June 22, 2012 This is what I got ... so if anyone can reccomend a slim line fan set up.. Hoping to gain 3/4 to an inch 1 Quote Link to comment
Lockleaf Posted August 16, 2016 Report Share Posted August 16, 2016 Adding a little to Charlie's how-to. I just did this job, but took a slightly different approach. I noticed when I had unscrewed and removed the front of the clutch that the whole back half is pressed on to the shaft, then the end of the shaft is flared out to hold everything in place snugly. I made a few relief cuts and then pressed the clutch off the shaft. The tip of my puller was too big to press down through the center of the clutch, so I put a socket in under it. That worked fine. In this one you can clearly see the relief cuts I cut into this, hoping it would allow the flare to collapse more easily. It worked out great. Little effort and not much time invested. Then I cut off a large chunk of the shaft with a cut off wheel on my grinder and then finished the edges and top off some with my dremel and a sanding drum. 1 Quote Link to comment
Charlie69 Posted August 16, 2016 Author Report Share Posted August 16, 2016 I had a friend do this mod to his 510 and for added assurance he put a couple tack welds on the pulley to the shaft. He has been running this way for about 5 years now. Lock Leaf at the time I did this I do not believe I had a puller available. Nice to know it can be done that way, less mess. 1 Quote Link to comment
datzenmike Posted August 16, 2016 Report Share Posted August 16, 2016 This is perfect. My first one, years ago was cut flush. The pulley wobbled off in less than a block. 3 Quote Link to comment
spdcrazy Posted August 21, 2016 Report Share Posted August 21, 2016 this totally made my night! exactly what I needed. 1 Quote Link to comment
Charlie69 Posted August 27, 2016 Author Report Share Posted August 27, 2016 Great write up Lockleaf and keep up the good work. Lockleaf this might be a great place to start a thread on different wiring scenarios. I know you are getting heavily into wiring as you have reached out to help me and I thank you. If you would like I will even redraw them up for you like I did the one you helped me with. Quote Link to comment
Lockleaf Posted August 27, 2016 Report Share Posted August 27, 2016 Once I wire the fans, I would be happy to put together a how-to. I want to give the design a decent beating before I really start claiming it works :) 1 Quote Link to comment
