Icehouse Posted May 15, 2007 Report Share Posted May 15, 2007 Are you going to have to run longer wheel studs? Thats a lot of brakes!! Especially for a L motor :D Quote Link to comment
slodat Posted May 15, 2007 Author Report Share Posted May 15, 2007 That strut and hub are spares for mocking things up. The studs on the car are plenty long enough for the spacers. Yea yea, I hear you snickering over there Iceman. You wait until that L motor's intake is no longer running at a vacuum! Then we shall see what you really think of L motors :) Quote Link to comment
kiznook Posted May 15, 2007 Report Share Posted May 15, 2007 so you need bigger spacers than the ones you were previously using? Quote Link to comment
Icehouse Posted May 15, 2007 Report Share Posted May 15, 2007 What master are you running.... Did you mention it somewhere and I missed it? Quote Link to comment
slodat Posted May 15, 2007 Author Report Share Posted May 15, 2007 I have 15x7 wheels with 21mm offset. I was running a 6.5mm (1/4") spacer to clear the strut tube/coil over sleeve. I need 13mm (1/2") to clear the caliper well. I have plenty of clearance with that amount of spacer. That means a ~8mm offset wheel would be perfect in 15" or the more likely option is a 16" wheel with a 14mm or so offset. The spacers I just ordered are machined not cast, so I don't see them being a problem. I'm running the ZX master that is on the car for now. If I find I have a volumetric issue, I'll figure out a plan at that point. My current backup plan should the ZX not move enough fluid to have a good pedal, is a properly sized Wilwood dual master. Quote Link to comment
Icehouse Posted May 27, 2007 Report Share Posted May 27, 2007 Check out this rig.. Quote Link to comment
slodat Posted June 5, 2007 Author Report Share Posted June 5, 2007 Thanks for the photo Iceman! I don't have any of the beginning. I'm doing my best to get the car running for Canby. Have had some shit going on and needless to say, the car hasn't been touched in a couple weeks. Wish me luck. I have 2.5 days. Anyone wanting to come by and encourage, please do!!! Quote Link to comment
Icehouse Posted June 6, 2007 Report Share Posted June 6, 2007 I was surfing the net and ran across it, I thought you might like it :D I just can't believe its Canby again!! Quote Link to comment
slodat Posted June 14, 2007 Author Report Share Posted June 14, 2007 After having a major fight with the car, I decided we should make up and went back to work. No more than I got the front hubs apart and the new bolts on and another stumbling block. The wheel spacers' center hole is 66.1mm and needs to be ~70mm. Uggh.. Mike (dislexicdime) pointed out to me that I am building a custom car. ie: par for the course. So, I'm hoping the guy that made them (to application - 280ZX) will send me another set that are the correct size. Quote Link to comment
Green Bastard Posted June 14, 2007 Report Share Posted June 14, 2007 Slo, Can you turn down the shoulder on the hub to match the hole on the spacer? Quote Link to comment
mklotz70 Posted June 14, 2007 Report Share Posted June 14, 2007 Come over sunday morning with hubs or spacers....I'm sure we can figure out how to get them to fit :) Quote Link to comment
kiznook Posted June 14, 2007 Report Share Posted June 14, 2007 sunday morning, would that be like datto church? i might be game. whatcha say steve? Quote Link to comment
slodat Posted June 14, 2007 Author Report Share Posted June 14, 2007 I just talked to Mike (dislexic) and he said something about Saturday morning at your house Mike (Klotz). Saturday is better for me. Which is it? Quote Link to comment
Duke Posted June 14, 2007 Report Share Posted June 14, 2007 After having a major fight with the car, I decided we should make up and went back to work. HAHAHA, I just had one of those, but I put that bitch back in line. Quote Link to comment
mklotz70 Posted June 14, 2007 Report Share Posted June 14, 2007 umm...either is fine. Get here about 9am.....I can only stay up until about 1pm.....so maybe come sat and we can carry over to sun if needed. Quote Link to comment
Icehouse Posted June 14, 2007 Report Share Posted June 14, 2007 My vote is you start on the rear brakes ;) Quote Link to comment
kiznook Posted June 14, 2007 Report Share Posted June 14, 2007 Im down for Saturday morning. Lets do it! Quote Link to comment
