bilzbobaggins Posted September 14, 2009 Report Share Posted September 14, 2009 (edited) Battery is boiling.....voltage climbs at battery when running.... I know i should change regulator w/ alt but should i try just regulator first?? And where is that sucker...the diagram doesnt help my dumb ass thanks jeff 70 521 L16 Edited September 14, 2009 by bilzbobaggins Quote Link to comment
Jester Posted September 14, 2009 Report Share Posted September 14, 2009 Do a search for the internally regulated alternator. That way you can do them both at the same time. :D BTW, Welcome to Ratsun. Quote Link to comment
5tinguy Posted September 14, 2009 Report Share Posted September 14, 2009 Your battery could have a bad cell and causing your charging system to over charge. Quote Link to comment
bilzbobaggins Posted September 14, 2009 Author Report Share Posted September 14, 2009 The guy who had it b4 me has i custom battery holder(bungee cord) the hooks had pulled up the caps on the battery and there is what appears to be corrosion on the fender well and the valve cover...think it might have sloshed out if there isnt enough battery fluid, what do i replace it with?? thanks jeff thanks for the welcome Quote Link to comment
Jester Posted September 14, 2009 Report Share Posted September 14, 2009 Distilled water is what is recommended. I just get mine frorm the sink.:D Quote Link to comment
bilzbobaggins Posted September 14, 2009 Author Report Share Posted September 14, 2009 is the voltage regulator the larger of the 4 boxes on the pass fender?? still cant find my damn camera cord for pictures... grrr thanks jeff Quote Link to comment
banzai510(hainz) Posted September 14, 2009 Report Share Posted September 14, 2009 (edited) on a 521 its near the fuse box but up and under the passenger fender well and should look like a 6 pin connector. I think 5 wires are only used. now if it overvolts then its the volt reg should look like this one below in photo. Get a solid state one if possible Wells brand or sold thru carquest. or a Jap made mechanical one. The ones from Napa Suck and are made in USA units. the smaller one is a solid state one. taller mechanical. note the connector and u shoul be able to find this. I just run a standard size 24 battery or whatever it needs. Im hoping the volt reg connector is standard as later 521 but I have seen different set up on the alternators themselves so always make sure on a alternator swap everything can swap as I have seen differnt set up on the ealy model of the 521 and early 510s get a cheezy volt meter for a few bucks and plug in cig lighter so you catch this next http://www.amazon.com/Equus-3721-Battery-Charging-Monitor/dp/B000EVWDU0?&camp=212361&creative=391349&linkCode=waf&tag=online0a-20 Edited September 14, 2009 by banzai510(hainz) Quote Link to comment
bilzbobaggins Posted September 14, 2009 Author Report Share Posted September 14, 2009 its on the fender well by the fuse panel what about one from oriley?? calling for pricing on the second one http://www.oreillyauto.com/site/c/search/Alternator+Voltage+Regulator/02115/C0330.oap?make=Nissan&model=521+Pickup&year=1970&vi=1212310 thanks dude jeff Quote Link to comment
Guest Rick-rat Posted September 15, 2009 Report Share Posted September 15, 2009 My battery was boilng for about 2 weeks, when the battery exploded it made a hell of a mess and did some body damage to the hood. Mine was a bad voltage regulator and a battery with a shorted out cell Quote Link to comment
Skib Posted September 15, 2009 Report Share Posted September 15, 2009 Distilled water is what is recommended. I just get mine frorm the sink.:D dis-still-water :lol: Quote Link to comment
