moparvwfreak Posted September 12, 2009 Report Share Posted September 12, 2009 with or without transmission???? and no i am not cutting the core support to pull the motor. i will be pulling the motors on BOTH 620s and mix-n-matching the parts. i have a good trans in my 73 but a good motor in the 78. also for now, i am going to use the clutch out of the 78 since its already installed. and yes i will be using the L20 TO bearing to be safe. Quote Link to comment
hessianben Posted September 12, 2009 Report Share Posted September 12, 2009 IMO, it's plenty easy to pull the motor/trans together. you will want to pull the steering center link (it helps to have a steering rod puller tool. you can rent from kragen...) and you will want to have plenty of head room- and a leveler on your hoist! Quote Link to comment
lynchfourtwenty Posted September 12, 2009 Report Share Posted September 12, 2009 IMO, it's plenty easy to pull the motor/trans together.you will want to pull the steering center link (it helps to have a steering rod puller tool. you can rent from kragen...) and you will want to have plenty of head room- and a leveler on your hoist! what he said ^^ btw i think you can use a hammer on the steering link not sure tho.. Quote Link to comment
Bugeye Posted September 12, 2009 Report Share Posted September 12, 2009 i used a hammer, dont forget to take the shifter off first though, it took me an hour to figure out why i couldn't get the damn engine/trans out of the truck Quote Link to comment
moparvwfreak Posted September 13, 2009 Author Report Share Posted September 13, 2009 IMO, it's plenty easy to pull the motor/trans together.you will want to pull the steering center link (it helps to have a steering rod puller tool. you can rent from kragen...) and you will want to have plenty of head room- and a leveler on your hoist! alright. will do. already have the leveler and a 2 ton hoist. i am going to be pulling both hoods with hinges so i dont have to realign the hoods when i put them back on. what he said ^^ btw i think you can use a hammer on the steering link not sure tho.. i should be able to. if i have enough room i used a hammer, dont forget to take the shifter off first though, it took me an hour to figure out why i couldn't get the damn engine/trans out of the truck thats the next thing to come out of both. that way i can make sure i have all the hangups out of the way. also where is the best place to chain the motors up at? the L16 wont be a problem as i have the head off and can use head bolts to attach the chains (eventually i will be rebuilding the motor with ARP head studs and what not so i dont care what happens to the old bolts.) but the L20 is still complete. Quote Link to comment
hessianben Posted September 13, 2009 Report Share Posted September 13, 2009 what he said ^^ btw i think you can use a hammer on the steering link not sure tho.. DONT DO IT!!! :( that's what I did first... and I mashed my threads to shit. now I have to doctor them back into shape... beh.... it's worthwhile to use a puller... shit it's worth it to but a good one to have and rent out to friends- you'll need it again eventually!!!:D Quote Link to comment
moparvwfreak Posted September 13, 2009 Author Report Share Posted September 13, 2009 DONT DO IT!!! :( that's what I did first... and I mashed my threads to shit.now I have to doctor them back into shape... beh.... it's worthwhile to use a puller... shit it's worth it to but a good one to have and rent out to friends- you'll need it again eventually!!!:D i know better than to pound on the threads. you use the hammer on the outside of where the thread goes in. just smack it a few times and it'll pop. but if all else fails, i think i have a separator somewhere in this mess i call a shop. somewhere and think are the key words though :) Quote Link to comment
hessianben Posted September 13, 2009 Report Share Posted September 13, 2009 i know better than to pound on the threads. you use the hammer on the outside of where the thread goes in. just smack it a few times and it'll pop. but if all else fails, i think i have a separator somewhere in this mess i call a shop. somewhere and think are the key words though :) hehe, I have it hell with the BFH all around it- on the pitman arm, but no budge. Quote Link to comment
yello620 Posted September 13, 2009 Report Share Posted September 13, 2009 Mopar, if you loosen the tie rod nut, but dont completely remove it, then you dont haveto worry about a little hammer slip hitting the threads.:D Remove the nut after the rod comes loose from the centerlink. Quote Link to comment
moparvwfreak Posted September 13, 2009 Author Report Share Posted September 13, 2009 Mopar, if you loosen the tie rod nut, but dont completely remove it, then you dont haveto worry about a little hammer slip hitting the threads.:D Remove the nut after the rod comes loose from the centerlink. that was the plan Quote Link to comment
moparvwfreak Posted September 26, 2009 Author Report Share Posted September 26, 2009 motors out on the 78. i couldn't find my seperator so i just yanked the trans. btw, prefer to pull a short tail vs a long. i ended up yanking the clutch, which looks AWESOME, in order to drop the trans. but all in all it was a 3-3.5 hour from start to finish. most of the time spent pulling the trans, assembling and adjusting my hoist so i could pull the motor. might just the clutch that was on the L20 for now as i am in a cash bind. should i swap TO bearings on the sleaves or just leave the one i have in the 73 on that sleave and call it good??? Quote Link to comment
moparvwfreak Posted September 26, 2009 Author Report Share Posted September 26, 2009 i also had another question. the Tstat housing is broken on my L20. well cracked and i would like to replace it. the one on my L16 is perfect. can i swap the two??? Quote Link to comment
Guest DatsuNoob Posted October 1, 2009 Report Share Posted October 1, 2009 Me thinks yes Quote Link to comment
DatDoug Posted October 1, 2009 Report Share Posted October 1, 2009 A lil trick of the trade............ just turn the steering wheel to one side or the other and it gives you enuff room:cool: Quote Link to comment
moparvwfreak Posted October 1, 2009 Author Report Share Posted October 1, 2009 a little late. both motors are out now. but i'll keep it in mind fo rthe next 620 i do a swap in. Quote Link to comment
