510 parts
i have some parts for sale.
i have a pair of two door seats that have been recovered in black vinyl slip covers. real nice $100
aftermarket front swaybar with fairly new poly bushings $60
tc rods with poly bushings $30
i will continually add more parts, so stay posted!
  • Replies 43
Hi, are you willing to ship the seats using greyhound. if you are will you give me a price quote from you to me at 91107. im paypal ready. thanks
sorry man these are probably going to be local sale only.
the sway bar diameter is one inch 1"
msd 6al cdi ignition box.tested and works great.no rpm pill. $60
aem multi channel cdi ignition module. works great. comes with harness and bypass plug. $80
68 wiper motor,plate, and linkage. in awesome shape. it was either from a real low milage car or it was rebuilt. almost no play on the pivots. painted satin black. very firm on price. $160
i was going to rebuild my l18, but i dropped in a ka. some rebuild parts i have left.
l 18 clevite 30 over dished pistons (matched set),high tech cast 30 over rings,l18/l16 high tech rod, and main bearings. standard size. sold as a set $140
68-69 front turn signal assemblies. in ok shape. missing one bullet connector. $25
water outlets of an l16. in good shape. lower outlet has a port blocked off. $25
lower hood latch $10
left headlight assembly $25
early master clylinder $20
hood cowl's $10 a piece
4 door driver front window $20
wagon rear bumper filler $10
moustache bar $10
gas door $15
door latch handle set $25
window crank handle set $25
3 door latch and 1 busted window handle $18
heater control facia $10
