haubstr Posted October 4, 2007 Report Share Posted October 4, 2007 Does anyone have part numbers for the replacement bushings for the front end of a '71 521??? Thanks Quote Link to comment
ppeters914 Posted October 4, 2007 Report Share Posted October 4, 2007 Interesting. I went thru the 521 parts manual that Paul (71-521) scanned and posted on ODPL. It shows the bushing in the drawing, but doesn't list a part number. Nothing on RockAuto.com either. Quote Link to comment
banzai510(hainz) Posted October 4, 2007 Report Share Posted October 4, 2007 control arm bushing?? http://www.rockauto.com/catalog/x,carcode,1212321,pgname,Suspension,partGroup,27 my local NAPA store had these in stock. when worn front wills will have alot of camber they also have KINGPIN sets, but a pain to change. Mklotz has done these http://www.nwde.org/extras/forum/forum_posts.asp?TID=4234&KW Quote Link to comment
ppeters914 Posted October 4, 2007 Report Share Posted October 4, 2007 Crap. Can't believe I missed that. Thanks for the save, you L motor god you. :D Quote Link to comment
mklotz70 Posted October 5, 2007 Report Share Posted October 5, 2007 Those are the upper/outer bushings and easy to get. I buy them locally down here. There are no rubber bushing at the inner/upper and lower/outer locations and I don't know if there are any in the lower/inner. I've never heard of anyone replacing in the inner/lower. Quote Link to comment
ADrummond Posted October 11, 2007 Report Share Posted October 11, 2007 There are lower inner bushings, and they're a pain in the ass to replace - but that's probably not a big deal, since I can't imagine them wearing out all that often. They're pressed into the frame, and you've got to burn the rubber part then saw the steel sleeve out. They're the same as in the drum brake 620, available from Rockauto.com and probably everywhere else. If you're looking for the rest of the front end rubber parts, like seals and the clips that hold them on, go to nissanparts.cc and be prepared to wait for six weeks while your order sits on the shelf. Andrew Quote Link to comment
mklotz70 Posted October 12, 2007 Report Share Posted October 12, 2007 I was just under a truck yesterday and noticed that the lower/inners did indeed have bushings :) Probably like the front leaf spring bushing....never seen a worn out one. If it did.....I'd make one out of delrin :) Quote Link to comment
datsun76_620 Posted April 14, 2008 Report Share Posted April 14, 2008 I'm getting ready to burn my Lower/inners out.... any hints on pushing/pressing the new one in??? Quote Link to comment
