WTS NapsZ Fuel Injection System w/ ecu and harness
I am selling an OEM fuel Injection System. I had this for a 2.0 NapsZ engine I was going to swap into a 510. All these components were from a 1980 Nissan 200sx with a 2 liter NapZ. I have the following components:
Complete wiring harness. This is brand new and never been installed.
A slightly used 1980 ECU has about 5K run time. The car was totaled in 1980 shorly after being purchased.
Upper and lower intake manifold with the injectors. (from the same wrecked car)
8 wire distributor.
I don't have the throtle body.
parts are all a bit dusty, but in excellent condition.
I would like to get $150.
thanks
Edited by qmrp2567
  • Replies 6
It was used on the '80-'81 Z20E and '82-'83 Z22E 200sx and used multi port injection. The first throttle body injection I can think of was on the '86.5 D-21 Hardbody with the Z24i motor. Though very rare, some very late '76.5 720 also got this Z24i TBI motor.
Rare huh? does it look like this?
This is out of an 86 720 4x4 bout 20 minutes from here, guy is parting it out. bottom end rod knock.
Yes, the Z24i TBI is characterized by having two wing nuts holding the air filter on. It has a high pressure fuel pump, maybe in the tank, an O2 sensor and an ECU under the pass seat.
The '76 FSM does not have a section dealing with the TBI set up. The Holy Grail of '86 720 owners with the Z24i motor is to find the ultra rare '86.5 FSM supplement that does detail the throttle body injection in detail. In a pinch the Hardbody FSM will do.
Edited by datzenmike
  • 1 month later...
