Datsun 510 521 and 240z Weatherstripping
All of these are for a 510 unless noted other wise
non of these are NOS, so no these are not 40 years old
more stuff comin, this is just a start.
FRONT WINDSHIELD 65.00
REAR WINDSHIELD 120.00
CHANNEL FELT 36.00/PAIR, will work on 240z
2 DR 1/4 WINDOW GLASS SEAL 1 PR 120.00
2 DR WEATHER SEALS NON MOLDED 48.00/ PAIR
2 DR 1/4 WINDOW WEATHER SEAL NON MOLDED 36.00/PAIR
4 DR FRONT WEATHER SEAL NON MOLDED 42.00/PAIR
4 DR REAR WEATHER SEAL NON MOLDED 41.00/PAIR
4 DR OUTER SQUEEGEES FRONT + REAR 68.00/SET
2 DR OUTER SQUEEGEES 42.00/PAIR, will work on 240z
HOOD BUMPERS 28.00/SET
KEY CHAINS 10.00 EACH
WIPER SHAFT BOOTS 5.00/PAIR
SIDE MARKER RUBBER 32.00/SET
WAGON LICENSE PLATE RUBBER 25.00/PAIR
ANTENNA 15.00/EACH
70-73 FRONT TURN SIGNAL SEALS 15.00/PAIR
INNER SQUEEGEES 30.00/PAIR
69-73 REAR TAIL LIGHT SEALS 44.00/SET
INNER 27.00/PAIR
OUTER 27.00/PAIR
DOME LIGHTS 25.00/EACH
70-73 EURO TURN SIGNAL ASSEMBLIES 60.00/PAIR
WHEEL CAP STICKERS 15.00/SET
TRUNK SEALS 39.00/EACH
DOOR WEATHER SEALS LEFT + RIGHT MOLDED 54.00/PAIR
2 DOOR 1/4 WINDOW WEATHER SEALS LEFT + RIGHT MOLDED 72.00/PAIR
ENGINE COMPARTMENT SEAL 22.00/EA
521 TRUCK FRONT WINDOW 60.00/EA
521 TRUCK REAR WINDOW 60.00/EA
I will take paypal if you want it shipped, via ups ground only
Edited by zhiguli510
  • Replies 6
Regarding door weatherstrip for a 240Z... I ordered the kit from MSA without reading up on it and it's WAY too thick - Doors won't even close correctly. Apparently it's a common problem.
Do you have the correct 240Z door weatherstrip?
All of these are for a 510 unless noted other wise!!!!!!!!!!!!!!!!!!!!!
available for pick up in Palo Alto 11am - 4pm Sundays
I accept paypal and will ship ups ground
sss steering wheel in almost perfect condition $250obo :D
non of these are NOS, so no these are not 40 years old.
ANTENNA 15.00/EACH
INNER 27.00/PAIR
OUTER 27.00/PAIR
  • 3 weeks later...
FRONT WINDSHIELD RUBBER 65.00
REAR WINDSHIELD RUBBER 120.00
2 DR OUTER SQUEEGEES 42.00/PAIR, will work on 240z will get more soon
WIPER SHAFT BOOTS 5.00/PAIR will get more soon
ANTENNA 15.00/EACH
INNER 27.00/PAIR
OUTER 27.00/PAIR
DOME LIGHTS 25.00/EACH will get more soon
521 TRUCK FRONT WINDSHIELD RUBBER 60.00/EA
521 TRUCK REAR WINDSHIELD RUBBER 60.00/EA
