Ryans 521 Build
Hello everyone,
I finally found a direction I am pointing my truck to. I know before I had lots of ideas and you guys really helped me decide where I want to go with this truck.
I am going to post a few pictures of the progress I am making, Bob3 has made a huge impact on the direction of my build. Mine will be similar to his but a little more radical. He is putting the Miata guts and bolts into his 520. Well I am doing the same thing but I am doing the Monster Miata Swap into my 521.
All the unneeded metal is taken off the frame, the K member is mostly modified for what i need, and I should be welding it up today
More to come as soon as the photo's upload
  • Replies 157
motor is already in the machine shop, and i have a spare so i can do a mockup.
i am putting a 302 roller ford from a a 1989 efi mustang with a 5 speed. the motor is going to have forged pistons and rods running low compression with a pair of t3 turbos which should run 350hp easily with room to grow.
rear end is going to be a lsd 7.5 ford diff with the mounting hardware from martin @ monster miata. i am also getting his axles and hubs
i am going to cage the truck and prepare it for running low 11s at the track and since i am modifying the floorpan/firewall, i am forced to run a cage and not just a rollbar.
just so u guys know this is not only going to be a straight runner. i love canyon carving and it will be pulling double duty.
i cant wait to start making some real progress here soon
ryan
Man...I'm dyin to find a nice 521! Keep the pics comin. As for the welding...the cleaner the area the better, and the more area around the weld you clean off the better - if the paint/grease is smoking/burning around your welds it can cause problems even if you're not welding directly on/over it.
very good point. i had grease 3 inches away and it was sizzling... the problem i was facing the most was the wind. it kept on contaminating my welds....
I had the same question, but the v8 miata guys swear by them. they have said they have never seen one break at all. and that is 450hp+. if it ends up breaking then at least i have my weak point in the system and those are cheap in the junkyard....
450hp and how much torque?
Here are some photos from todays work:
Just realized i should connect those welds:
Those plates are to hold the rear in place while i fabricate the final holders in place:
Thats it for today....
Edited by BACARDI_DWB
Don't measure from the tire to see if your centered. The camber / alignment could be WAY off from side to side. Be sure you measure to the frame to the subframe.
Looking good!
Looking good!
yeah i measured from the subframe to the frame. i was just showing how much tire i am going to beable to fit in there.... Thanks for the heads up thou!!...
I am going to do my rear coilover setup a little bit different than yours. I am going to put a QA1 coilover in the rear mounted on the arm and then bolted to the underside of the frame, that way i have more room for different tire combo's
cleaned and painted for right now to ensure it doesn't rust any further. I have alot of traveling to do within the next 3 months so i wanted to make sure everything stayed rust free. I may sandblast it and repaint it after all the frame modifications are done, I still have alot of work to do to make that 5.0 ford fit that front K member.
