L18 & Weber Carb ID
atkinson40
  • Replies 2
You can't, at least not without knowing the serial number ranges. In fact it might not be a US-spec L18 either. All but one of my L18s are late 70s JDM ones, with different "specs". Likely your engine is a mutt anyway, with the L16 intake/exhaust bolted to the L18 (JDM L18s had twin SUs or EFI on them, but generally that stuff was removed when the engines were imported).
As fro the Weber, the model number and type are stamped on the base. The lack of an anti-dieseling solenoid is normal- 95% of them don't have one.
