copacetickid Posted September 27, 2007 Report Share Posted September 27, 2007 I did a tranny swap on my 620 a month ago, and somehow (although I was careful) the key broke off of the cable at the transmission's end. Damn! I'm pretty sure it isn't repairable. Link to comment
datzenmike Posted September 27, 2007 Report Share Posted September 27, 2007 Find one at the wreckers, loosen the tranny end and pull it out. Wrap around waist under shirt and go home. Link to comment
Jason Posted September 27, 2007 Report Share Posted September 27, 2007 If I'm correct then you can order a 80" speedometer cable from Autozone that's meant to be a replacement part for the 1969 automatic Datsun 510. I just put one into my wagon and it works great. I think the part number is CA-3081, I'll check tonight and edit this post if it isn't correct. I think it was $22 up here and it lists for something like $19.99 in the states.... Link to comment
OL YELLER Posted September 27, 2007 Report Share Posted September 27, 2007 If I'm correct then you can order a 80" speedometer cable from Autozone that's meant to be a replacement part for the 1969 automatic Datsun 510. I just put one into my wagon and it works great. I think the part number is CA-3081, I'll check tonight and edit this post if it isn't correct. I think it was $22 up here and it lists for something like $19.99 in the states.... Pep Boys has em too.something like 20 bucks also..one day turn around..easy Link to comment
