u joint question
I am trying to figure out if the u joints on the driveshaft and the rear axles are same. I looked through every thread in the drivetrain section on here and on the that other site(realm). I searched the net and there are so many different part numbers. I am going to swap my rear end and figured while I have it out I might as well do some preventive maintenance by swapping the u joints at the same time. I know that I need 6 of them. Questions are, will they all be the same and what brands are recommended.
Thank you
Kevin
  • Replies 4
there different
look at Rockauto.com
importedcarparts.com
do some x ref on those #s
40$ made in USA ones are the best but I have run the Japanese GMB brand with OK results but I dont beat my car much anymore. raise it up also so not to much angle on the half shafts
Thank you
Kevin
Whats up Kevin, go to Napa Auto Parts, they have Precision brand u-joints, US made supposely, around $23 bucks each, Napa in Long Beach off of Long Beach Blvd
Thanks George I went to that exact napa and got them today.
good deal!! did you get them for the axles and drive shaft? they are different
