DatsunMotorSports Posted August 13, 2009 Report Share Posted August 13, 2009 (edited) I have a project 240Z that I am letting go of. I have spent tons of time on this car and I am really attached to it. manufacture date 3/71 The shell is 90% stripped to metal. Here is a very specific list of what the car comes with. If its not on the list I may not have it.--------------------------- T5 5spd transmission and 72 4spd front suspension with rack n pinion rear suspension with no brakes axles or diff. Blue lowering coil springs and stock coil springs Front windshield Dash with gauges wire harness(all) Rear hatch no glass and a rear hatch with vert lines glass doors with pretty much everything 1/4 windows radiator cowl brake and fuel lines fuel tank for fuel injection 1972 center console front brakes brake master cylinder and booster bare fenders Most of the interior stuff replacement roof hood tail lights +1 turn signals and a few other misc pieces that I have for it. Asking $650obo pink in had with clear title. non-opp. cash up front. ----------------------------------------------------------- Im also thinking about selling a RHD clip with it. $1100 for both. The fairlady clip has AC components as well as an extra dash and pedal assembly. The Fairlady clip is a '78 but has vintage ca plates so no smog either under its vin if it were ever brought back. I will not sell the Clip Separate. It is offered with the '71 only or not at all. I also will not part either out. Sorry fairlady has fairlady headlight buckets without chrome rings or clear covers front valance cross member with RHD rack n Pinion steering column pedals and assembly Brake system complete all related RHD stuff needed except cowl cover 2 complete dashes and pedal assemblies complete wire harness I have a Mid sump LD28 Bottom end. It has the LD28 crank(needs to be taken to a crank repair place for a damaged #2 journal). It consists of V07 Block V07 crank(needs repaired) 5L mid sump oil pan and pickup Homemade(not mine) T3 turbo header P90a head with good lifters, but no rockers(I pulled from a running engine I drove for ever) water to oil cooler Stock turbo cam... but I was going to use a custom cam it just happens to be with the P90 head still. Machine work still required for the new 10mm head bolts. Needs Z22e rods, custom pistons, gaskets,harmonic balancer, internal balancing, L20B parts(timing cover, chain tensioners, and chain)... still. I have your choice of intake parts. I have a N42 EGR style intake and I have the LD28 intake I also have SU intakes with carbs if you want to go that route I can get you started. The block is a mid sump and bolts into the Z. There is a lot of work needed as these are just the raw parts to start a project. I have 2 of these setups and Im not going to build this twice. Its just taking up floor space and i could use the money towards my other projects. stroker is available seperately and is listed on multiple other websites so its only available if it hasnt yet been sold. asking $250 obo seperate from car. I also have a Viscous Limited Slip long nose R200 carrier section with companion flanges. Included is a R200 open diff with 3.54 gears. $200 the Center section is from Japan. The housing is the same as Datsun Z. The closest thing I have seen to this VLSD is the Q45 diff internals, though Im not sure the Q4 diff will fit in a long nose R200. Ray 831-402-5387 Edited August 13, 2009 by DatsunMotorSports Location Link to comment
Guest DatsuNoob Posted August 13, 2009 Report Share Posted August 13, 2009 uhhhhhh.... location? :blink: Link to comment
Mark_Z28 Posted August 13, 2009 Report Share Posted August 13, 2009 The R200 viscous LSD, what is it out of? I need one for my 240SX and if its out of a Infinity J30 or a newer 240SX it will work. Link to comment
DatsunMotorSports Posted August 13, 2009 Author Report Share Posted August 13, 2009 Sorry not sure what I was thinking. Thought there was something missing from my Title. Im in Sacramento Ca 95827 Ray Link to comment
Jester Posted August 14, 2009 Report Share Posted August 14, 2009 WOW!!!!! Good stuff Ray. Wish I was closer and had the money. Good luck with your sale. Link to comment
DatsunMotorSports Posted August 15, 2009 Author Report Share Posted August 15, 2009 Last Call! I dont want to do this, but Im down to it. I know Ive only had it listed for just over a week. I am now faced with cutting up the car. I dont want to piss the neighbors or the city off at me so having a 2 car garage and 2 car driveway with 6.5 cars is ridiculous. So everything on the list is for sale. No shipping available. If you want it its in Sacramento ca 95827 US50 and Bradshaw. If there is a ton left over by Monday I may ship, but mostly Im just going to call the recycler guy to come by. I have garbage shed with 2 S30 frames cut into little pieces already. It breaks my heart to have to do this to this car. Ive had it since I was in High School. If you want to get the whole thing speak up. Someone is already lined up to get the T5 and lowering springs. List what you want and what you want to pay. There is also the chance that I stay busy and that I will not be able to cut it up on Sun. That would be bitter sweet. 831-402-5387 Link to comment
Jester Posted August 15, 2009 Report Share Posted August 15, 2009 DON'T CUT IT UP!!! Holy crap. Someone go buy this car. What would you take for the car without all the "extra" stuff? Just the car and the "essentials". Link to comment
DatsunMotorSports Posted August 15, 2009 Author Report Share Posted August 15, 2009 "essentials"? Like rolling Chassis, not rolling, glass, no glass, etc? Make an offer. what exactly do you want for what amount. Lets work it out. I have the car listed on 8 or 9 different sites with no tangible proof that anyone really wants the car. I got 7 emails this morning asking if the T5 was for a mustang and how much... Come get what you want and make an offer for it. Link to comment
Yakuza Posted August 15, 2009 Report Share Posted August 15, 2009 HOLY SH**!!!:eek:...dont do it man....if i was closer i would get it... would you sell RHD stuff? if so pm me how much?:D Link to comment
Jester Posted August 15, 2009 Report Share Posted August 15, 2009 By essentials I'm talking just the basic car withouth the boxes of extras in the list. In Oregon it's hard to find a nice rust free 240. My daughter wants a 240 BAD. I can't really afford to come down, tow it back and all that right now. I have a good freind in Cali. that I could possibly store the car at till I can come get it. I just hate to see you cut it up. It looks like a great starter for someone. Link to comment
Yakuza Posted August 15, 2009 Report Share Posted August 15, 2009 Hope something/price gets worked out jester, its better if it goes to someone that will eventually build it then the sCRAPPER....good luck hope you get it for your daughter...:D Link to comment
DatsunMotorSports Posted August 15, 2009 Author Report Share Posted August 15, 2009 (edited) RHD complete clip make an offer. Its got Vintage plates for Ca so no smog. Stuff that is spoken for fenders T5 brake system all of it lowering springs flywheel and clutch hatch with 71 glass Possibly: white hood doors with pretty much everything tail lights +1 turn signals So from whats left the boxes on the inside of the car are full of its interior pieces, the wire harness's, and all the hardware for the car. So let me know exactly what you want with it and what would make it worth it for you and I will see if I cant accommodate you? Edited August 15, 2009 by DatsunMotorSports listed hood twice Link to comment
Yakuza Posted August 15, 2009 Report Share Posted August 15, 2009 you're in Rancho cordova? or sac.? how many hours would that be from L.A.? im serious about it.. Link to comment
DatsunMotorSports Posted August 15, 2009 Author Report Share Posted August 15, 2009 Im in Sacramento Technically, but street signs say Rancho Cordova Call me, Ill give you my addy and you can google map me to get driving time. 831-402-5387 Link to comment
yello620 Posted August 15, 2009 Report Share Posted August 15, 2009 Jester, dont pass this up.:D That is not that far of a drive. About ten hours. And a 240 shell is super light, might tow just fine behind the 620.:D I have seen two guys pick up a bare shell before. Link to comment
Jester Posted August 16, 2009 Report Share Posted August 16, 2009 Kinda tuff to justify another rig when you don't have a steady income. Or should I say no income at the moment. :D We'll see. Road trip?? Link to comment
yello620 Posted August 16, 2009 Report Share Posted August 16, 2009 Road trip?? I'll go.:D When do we leave? Link to comment
DatsunMotorSports Posted August 16, 2009 Author Report Share Posted August 16, 2009 (edited) List of parts sold Bare fenders rusty hatch with vert glass center front valance blue hood passenger side rear plastic interior panel 1 of the 3 combo switches sets T5 transmission List of stuff spoken for, but not physically gone/paid for: tail lights turn signals flywheel and clutch white hood 1 set of doors with pretty much everything Selling off part by part. Will Strip the shell down to nothing. Take all the suspension and stuff off and sell that with a clean title for $150. Im planning on helping someone else out with their car tomorrow. hopefully that will take all day. Edited August 16, 2009 by DatsunMotorSports Link to comment
DatsunMotorSports Posted August 17, 2009 Author Report Share Posted August 17, 2009 I was able to strip the front of the car except the suspension. I took the doors off. I started to empty the rear out and a friend called me out to help get his car running. So I didnt get far to say the least. I was really hoping I wasnt going to get far though. So any excuse, right? Zero Follow-ups about the car on 7 different sites. People bought some parts, and now its dead. I go back to school for my Smog License here pretty soon, so the car needs to get handled ASAP! once Im at school this will not be possible. Ray Link to comment
AZhitman Posted August 17, 2009 Report Share Posted August 17, 2009 Ray - I need the chrome trim along the door glass (the squeegie piece), both sides. Would like a set of door panels as well, but I'm guessing they're shagged. PM with price shipped to 85387? Link to comment
72240z Posted August 17, 2009 Report Share Posted August 17, 2009 (edited) Any weather stripping worth using? If there at all lol. Edited August 17, 2009 by 72240z Link to comment
hoov100 Posted August 17, 2009 Report Share Posted August 17, 2009 i would totally take every single RHD part you owned, if i wasnt 600 miles away. Link to comment
DatsunMotorSports Posted August 17, 2009 Author Report Share Posted August 17, 2009 Door window squeegees available. I have some strait ones, but the rubber is old and hard. In fact i have a whole pile of them from other cars Ive cut up...:( Most of them have bad rubber squeegees. Crack rubber, hard rubber, etc Shipping is probably going to cost more than I want for those things. How about $10 for a pair of those chrome door squeegees plus whatever shipping costs are? Door panels are most definitely "Shagged", but taken by the guy who is taking the doors. Weather stripping was tossed long ago. I was going to buy the kit from MSA and hoped it fit right. Link to comment
DatsunMotorSports Posted August 18, 2009 Author Report Share Posted August 18, 2009 :eek: Suspension pending sale. Headlight buckets pending sale. Link to comment
