groatd Posted August 10, 2009 Report Share Posted August 10, 2009 can u put a l20 cam in a l18?????? Quote Link to comment
bonvo Posted August 10, 2009 Report Share Posted August 10, 2009 yes its considered a performance upgrade over an l18 stock cam Quote Link to comment
groatd Posted August 11, 2009 Author Report Share Posted August 11, 2009 would i have to change anything or can i just slap it l20 cam in and drive it away Quote Link to comment
Bugeye Posted August 11, 2009 Report Share Posted August 11, 2009 i would put the lash pads from the head that had the l20 in the new head Quote Link to comment
Jester Posted August 11, 2009 Report Share Posted August 11, 2009 Need a cam??? Have a BRAND NEW one of those too. :lol::lol::D Quote Link to comment
Bleach Posted August 11, 2009 Report Share Posted August 11, 2009 i would put the lash pads from the head that had the l20 in the new head And make sure that each lash pad gets installed in the exact same order in the new head. The wear pattern is unique and you want each cam lobe to be with the same pad it was in the prior head. Otherwise, put in new or refinished lash pads. $$$ The L20 cam is basically the L16 SSS cam. Hardly longer duration. You might get upwards of 4hp at the top end. Its not worth doing at all unless your cam is bad and you need to replace it anyway. Quote Link to comment
groatd Posted August 11, 2009 Author Report Share Posted August 11, 2009 so ur telling me it can be done but its not going to noticable? Quote Link to comment
Bleach Posted August 11, 2009 Report Share Posted August 11, 2009 Exactly. If you swap in an L20b, the extra torque (though not much) will be noticable. Some things are better left undone. Quote Link to comment
hang_510 Posted August 11, 2009 Report Share Posted August 11, 2009 i would put the lash pads from the head that had the l20 in the new head AND rocker arms = matched to the lobe they were removed from. Quote Link to comment
banzai510(hainz) Posted August 11, 2009 Report Share Posted August 11, 2009 groatd dont waist your time and risk something going bad. If anything build a motor on the side while this rig is running. Quote Link to comment
datzenmike Posted August 14, 2009 Report Share Posted August 14, 2009 It's also possible that the head you have has an L20B spec cam anyway. Quote Link to comment
