jhughes26 Posted August 9, 2009 Report Posted August 9, 2009 i have had a rough time trying to find a replacement for my lower ball joint, my car is a 69 and that may be the issue. the one that kragen got me didn't fit, i asked at Nissan and they had two that they could order but not return at $90 and $150 and i thought that was an expensive experiment for something that probably wont fit, and i sourced one from a dime specialty place, and it was the wrong measurements. the ball joint that i have has a threaded diameter of 3/8" and a 17 mil socket fits really nicely on the nut, cant be too exact on the diameter of the taper (dont have calipers) but it looks like it is 1/2" at the top and 11/16" at the bottom anyone had this problem? was considering going to machine shop to have the arm bored out to fit the new ball joint, but would rather not. anyone done this and know part numbers or somewhere i can get this? this is my steering arm that it mates to, would it be easier to get a new one of these that fits? thanks Quote
thisismatt Posted August 9, 2009 Report Posted August 9, 2009 There were 11mm and then 14mm IIRC. You just need to get a set of later steering knuckles and you'll be set. Quote
benzo Posted August 10, 2009 Report Posted August 10, 2009 from the pics it seems you may have 11 mm ball joints. They are still available as I was able to get them as I thought I had 14mm but found out my car came with 11mm units. if you can not get them let me know as i should be able to get them from you. Quote
oregondime Posted August 10, 2009 Report Posted August 10, 2009 http://www.rockauto.com/catalog/x,carcode,1209978,parttype,10070 Quote
BoostinBen Posted August 11, 2009 Report Posted August 11, 2009 Damn I just did the same thing but the other way round! .. I needed the 14mm and accidentlly bought the 11mm ones from rockauto. I reordered the 14mm since i was impatient and didnt want to bs with sending them back .. so I got an extra set of 11mm if you need em there for sale! :D Quote
jhughes26 Posted August 12, 2009 Author Report Posted August 12, 2009 oh oops bought one from napa yesterday at lunch sorry bro Quote
Jason Posted August 12, 2009 Report Posted August 12, 2009 Hmmm... Ben, I'd be interested in the 11mm ball joints if you want to get rid of them. Give me a pm ... Quote
jhughes26 Posted August 14, 2009 Author Report Posted August 14, 2009 11 mil fit great, got front end completely back together after having been apart for a long while when i was doing bushings, played "we are the champions" while cleaning up. good day Quote
