picotte21 Posted September 25, 2007 Report Share Posted September 25, 2007 hi guys i'm new to this forum and just thought i'd say hi and show you guys what i got 78 620 longbed swapped a dual plug engine and 5 speed from a newer dat into it a buddy and i did all the body work and paint its a fade proof suede black. my goal is to bag the rear end and finish the interior but for now this is it tell me what you guys think i'll try to get some higher res pics of it when i get the chance Quote Link to comment
tnip Posted September 25, 2007 Report Share Posted September 25, 2007 welcome, got a nice lookin 620 there. anymore pics? Quote Link to comment
picotte21 Posted September 25, 2007 Author Report Share Posted September 25, 2007 here is one of the engine crappy cell pics i know Quote Link to comment
spiffinspudater Posted September 25, 2007 Report Share Posted September 25, 2007 WTF engine is that!? is that from a newer 720? Quote Link to comment
tnip Posted September 25, 2007 Report Share Posted September 25, 2007 WTF engine is that!? is that from a newer 720? read the first post :rolleyes: Quote Link to comment
Fineline Posted September 25, 2007 Report Share Posted September 25, 2007 Looking good man. I especially like what I think is the sidepipe? Real Mad Max! Quote Link to comment
]2eDeYe Posted September 25, 2007 Report Share Posted September 25, 2007 Ya...SidePipe... :D Quote Link to comment
Rusty Posted September 25, 2007 Report Share Posted September 25, 2007 that thing is rockabilly!:) Quote Link to comment
tnip Posted September 25, 2007 Report Share Posted September 25, 2007 ha, i just noticed the cowl mounted gauge, is that a tach or what? Quote Link to comment
picotte21 Posted September 26, 2007 Author Report Share Posted September 26, 2007 thats the water temp gauge. ya thats a side pipe it might change here soon its a little loud right now. the buckets in it are from a 2nd gen 300z but they're a little big for my tall frame so i'm replacing them with smaller buckets from a 83 rx7. i might go really disco with the interior (red shag) but i dont know yet. i'm taking pictures of it tomorrow with my good camera so stay tuned. Quote Link to comment
datzenmike Posted September 26, 2007 Report Share Posted September 26, 2007 here is one of the engine crappy cell pics i know The stamped metal valve cover, fooled me into thinking it was a Z24. It has an L series fuel pump so only the Z20 and Z22 had the pump boss machined out, but with a cover plate, the Z24 was closed off. I would say a Z22. Here's mine, a '78 also, with a Z24 with P/S pump. I don't feel so alone now. http://i138.photobucket.com/albums/q251/datzenmike/IMG_0437.jpg[/img]"] Kudos to you and your buddy for figuring out that the L pump will run on the Z engine. Quote Link to comment
datzenmike Posted September 26, 2007 Report Share Posted September 26, 2007 WTF engine is that!? is that from a newer 720? read the first post :rolleyes: Could have been out of a 200sx, 510, Pathfinder, Hardbody or the Nissan van too. Quote Link to comment
Pacific coast Datsun Posted September 26, 2007 Report Share Posted September 26, 2007 Kool 620 & welcome to Ratsun where primer rules ! Interesting side pipe,ever burn your leg getting out ? :cool: Quote Link to comment
datzenmike Posted September 26, 2007 Report Share Posted September 26, 2007 Forgot to ask how you ran the exhaust, did it not line up with the stock pipe? Haven't done mine yet and don't want a side pipe. Did the 720 throttle cable reach ok? Are you running dual plugs on all the time or do they switch off with vacuum like the stock 720s? How does it compare to the L20B that was in it, more torque? Better bottom end? More pix please. Quote Link to comment
picotte21 Posted September 26, 2007 Author Report Share Posted September 26, 2007 Forgot to ask how you ran the exhaust, did it not line up with the stock pipe? Haven't done mine yet and don't want a side pipe. Did the 720 throttle cable reach ok? Are you running dual plugs on all the time or do they switch off with vacuum like the stock 720s? How does it compare to the L20B that was in it, more torque? Better bottom end? More pix please. when we picked up this truck the stock exhaust was rotted out and we just had some tubing lying around that worked perfect for a side pipe wasn't planned just happened that way we originally wanted to run it out the back and use c5 corvette tips in the center. the 720 cable wasn't even close i think we got the cable from a conquest or dodge caravan i cant remember. its running dual plugs all the time. its a ton quicker than the L20b spins the tires through 3rd when you want it too Quote Link to comment
picotte21 Posted September 26, 2007 Author Report Share Posted September 26, 2007 The stamped metal valve cover, fooled me into thinking it was a Z24. It has an L series fuel pump so only the Z20 and Z22 had the pump boss machined out, but with a cover plate, the Z24 was closed off. I would say a Z22. Here's mine, a '78 also, with a Z24 with P/S pump. I don't feel so alone now. http://i138.photobucket.com/albums/q251/datzenmike/IMG_0437.jpg[/img]"] Kudos to you and your buddy for figuring out that the L pump will run on the Z engine. thanks for the kudos it is a z24 we used a drill and a die grinder to open up the hole it was cheaper than buying an electric fuel pump and worked really well. the ignition was a pain to figure out how to make both the coils fire but when we figured it out it ran like a top Quote Link to comment
Bleach Posted September 26, 2007 Report Share Posted September 26, 2007 very nice... a 2.4L you should take that power steering pump off to save some weight. :) Quote Link to comment
spiffinspudater Posted September 26, 2007 Report Share Posted September 26, 2007 very nice... a 2.4L you should take that power steering pump off to save some weight. :) *pokes bleach* you should get a 620 and show us how it's done! Quote Link to comment
Bleach Posted September 26, 2007 Report Share Posted September 26, 2007 *pokes bleach* you should get a 620 and show us how it's done! haha... my Frontier would be jealous. I'm already being sneaky with 4 cars at my complex and we are only allowed 2 per person. :P Quote Link to comment
tnip Posted September 27, 2007 Report Share Posted September 27, 2007 4 cars... 2 per person... :: counts on fingers "carry the 6" :: what's sneaky? Quote Link to comment
datzenmike Posted September 27, 2007 Report Share Posted September 27, 2007 very nice... a 2.4L you should take that power steering pump off to save some weight. :) No way... I need P/S to turn those 33s. Here's a pix of the hard body P/S box before the transplant. I home made a pump mount for my L20B motor and this one already has it, a little plumbing, good to go. http://i138.photobucket.com/albums/q251/datzenmike/IMG_0426.jpg[/img]"] Quote Link to comment
datzenmike Posted September 27, 2007 Report Share Posted September 27, 2007 thanks for the kudos it is a z24 we used a drill and a die grinder to open up the hole it was cheaper than buying an electric fuel pump and worked really well. the ignition was a pain to figure out how to make both the coils fire but when we figured it out it ran like a top Dude that is so Ratsun! Figure it out and make it work, right on. I put an L pump on a Z22 head just to see if it would fit once. Scary how similar the L and Z are. Quote Link to comment
datsun dreamer Posted September 27, 2007 Report Share Posted September 27, 2007 welcome Home:D, Diggin' the pipe....My buddy had something like that on his harley! Quote Link to comment
lynchfourtwenty Posted September 27, 2007 Report Share Posted September 27, 2007 nice ride where you from?? Vancouver by chance? did i reffer you here?? Quote Link to comment
Bleach Posted September 27, 2007 Report Share Posted September 27, 2007 No way... I need P/S to turn those 33s. Here's a pix of the hard body P/S box before the transplant. I home made a pump mount for my L20B motor and this one already has it, a little plumbing, good to go. haha! That doesn't apply to you. He doesn't have power steering in the truck. You knew that and just wanted to show off your power steering assembly. :D Quote Link to comment
