4lug to 5lug on 610?
Dust
  • Replies 2
Can it be done? if so what is used to make my 610 73 wagon a 5lug?
Please...need to know ASAP!
First things first - you would need to find the solid rear axle with the correct width and bolting to swap out your R190 to get a 5 lug solid rear axle without causing handling problems. I could see that *maybe* the front struts from a 300ZX *might* be modified heavily to work on the front to give you better braking and the 5 lugs you seek. But this is all hypothetical. I know there have been 5 lug conversions done to 510s, and the thought would be that the 610 could fall into that category as well (as a lot of components are similar). I'm sure there will be more chiming in on this.
