dimedude Posted July 26, 2009 Report Share Posted July 26, 2009 hey every body i think i should introduce myself before getting to my question im new to the forum just picked up my seconded 510 project 1973 4 door with a L16 motor any ways...... i picked up a electronic match box dist today its from a 1980 pickup (code d4k8-08) i think and didnt get the pedestal that went with it is there any way i can make the stock L16 pedestal work thanks ps i tried searching for an answer and wouldnt find one Quote Link to comment
banzai510(hainz) Posted July 26, 2009 Report Share Posted July 26, 2009 watch my timming chain install vid on olddatsuns.com line motor up to TDC install distributor where it land will be your #! plug wire go 1 3 4 2 counterclockwise fire order. just C clamp the timming plate distributor down till you get a pedastall time it topsay 10Deg BTDC Quote Link to comment
dimedude Posted July 27, 2009 Author Report Share Posted July 27, 2009 thanks guys for the help i was able to modify the "L" shaped braket from the stock distributor and make it work Quote Link to comment
HRH Posted July 27, 2009 Report Share Posted July 27, 2009 watch my timming chain install vid on olddatsuns.comline motor up to TDC install distributor where it land will be your #! plug wire go 1 3 4 2 counterclockwise fire order. just C clamp the timming plate distributor down till you get a pedastall time it topsay 10Deg BTDC Dammit Hainz! Timing, not timming! :D Quote Link to comment
