Header bolts(L20)
makya
Ok, it's been awhile since I've swapped or rebuilt motors, so I need a reminder on how to get the bottom bolts on the exhaust header? I can't get a socket over the bolt head running it under the intake, and I can't get a ratchet in from the top(obviously).
How do you do it?
  • Replies 6
http://www.racetep.com/510start.html
you need to get it powder cosated cause the paint is CHEAP!!!!!!!!!!!
you could find a 510 exhause manifold but need a y pipe to fit a 4x and Racnjasn did this.
as for CARB approved I know nothing of these things.
the header is more for ease of install /removeal than true performance gains if a L16 exhaust manifold is not avail with Y pipe
I still run a L16 manifold on my beater with sidedrafts carbs
