stb210thegreat Posted July 17, 2009 Report Share Posted July 17, 2009 Greetings! I bought a 74 B210 from a dude who chopped the front springs 2 inches and added fairly tall cooper cobras. I think I am going to crack my tailbone driving it! He did mention that the shocks were toast:cool: I am looking for a much smoother ride, but still having it lowered. What springs will work for the car? Will simply changing out the shocks fix the rough ride problem? The wheels also rub a bit on sharp turns :-/ Thoughts/comments? I have a 77 that can be used as a parts car. I can bring the springs over from that....but then it would be stock again. How boring! Quote Link to comment
hang_510 Posted July 17, 2009 Report Share Posted July 17, 2009 do you have a set of spare tophats? i need to play with some. I can bring the springs over from that.... if you have stock spares, measure twice, cut 1 coil at a time. Quote Link to comment
philip1 Posted July 17, 2009 Report Share Posted July 17, 2009 240-280z springs are the same diameter they can be cut to be a stiffer lower spring or if you are rally racing leave the spring intact for a lift. Add to the springs a nice set of KYB or Tokico shocks and you will have a better ride without bottoming Quote Link to comment
Capital15 Posted July 19, 2009 Report Share Posted July 19, 2009 Do the 240-280 springs also fit the 210's?(120y's) Quote Link to comment
ggzilla Posted July 20, 2009 Report Share Posted July 20, 2009 No, too big around. You can use the rear 280ZX springs on the front of B210 I've never heard of composit coil springs -- are you sure? Make sure that you have some suspension travel. He may have fitted lowering springs/cut springs but kept the stock compression bumper. You may have to cut the strut bumper in halft to give an extra inch of travel. THis is avery common problem. Quote Link to comment
Capital15 Posted July 21, 2009 Report Share Posted July 21, 2009 Any year 280ZX rear springs will fit the front of any year 210? What about the rear for the 210's?? Anything compatible? Quote Link to comment
ggzilla Posted July 21, 2009 Report Share Posted July 21, 2009 Yes, ANY year 280ZX. That gives you a choice of 1979, 1980, or 1981. Don't know about the rear. Most people just cut 1/2 coil off the existing springs. Only rich guys or serious racers buy custom springs. Quote Link to comment
bonvo Posted July 21, 2009 Report Share Posted July 21, 2009 is it a b-210 or a 210 a b-210 will have leaf springs in the back Quote Link to comment
ggzilla Posted July 21, 2009 Report Share Posted July 21, 2009 Original poster asked about B210. But then Capital15 asked about 210. For any newbies that may be reading this, not that these are two different models: B210: 1974-1978 marketed as "Datsun B-210" B310: 1979-1982 marketed as "Datsun 210" Quote Link to comment
Capital15 Posted July 22, 2009 Report Share Posted July 22, 2009 Yes. I asked about the 210, not B-210. Thanks for the info. Quote Link to comment
b210in Posted August 6, 2009 Report Share Posted August 6, 2009 hey zilla, do you happen to know how stiff the rear springs on a 280 would be? i'm assuming more stiff than stock b210 springs. Quote Link to comment
philip1 Posted August 6, 2009 Report Share Posted August 6, 2009 (edited) early z springs are compatible with the 210/b310 as well. I used 240 rear springs in the front of my 210/b310 rally car and moved the front 210 springs to the rear. for a 3 inch lift. I swapped to the front springs when I installed the L20 they fit but these are z not zx springs Edited August 6, 2009 by philip1 Quote Link to comment
ggzilla Posted August 7, 2009 Report Share Posted August 7, 2009 First you might want to figure out why the ride is bad. 1. When one is lowered 2", it may be bottoming out (not a spring problem). There is a rubber bumper on the strut shaft, it's like 2" high, cut it down to 1" high will gain you spring travel. 2. The springs may be too stiff. Stock spring rate is about 100 lb/in. People replace them with 275 lb/in for racing o whatever but it's really rough riding (compare to stock) Cut the spring 1/2 coil at a time and check how far it lowers... Quote Link to comment
