Skib Posted July 15, 2009 Report Share Posted July 15, 2009 heres a little info I thought Id stick up here from Blues Tech Tips theres a ton more helpful info there too. The new ones with the push style clip Car Quest Part SK-25 Auto Zone part number is AZ #077926 GP Sorenson part number is 800-9213 AC Delco part number is PT-113 GM part number is 12085491 Here are two injectors readily available from a junk yard. A GM (from an Achieva and an Audi from an 89) The audi's are much better quality and include a hefty boot. The Audi had a 5 cylinder motor however there were enough connections in the engine compartment to do nearly two Zs. 2 Quote Link to comment
Phlebmaster Posted July 15, 2009 Report Share Posted July 15, 2009 Good info. :) 1 Quote Link to comment
Jester Posted August 3, 2009 Report Share Posted August 3, 2009 Thanks for the part number and the link. Great site with a $#!t load of info too. 1 Quote Link to comment
Skib Posted August 3, 2009 Author Report Share Posted August 3, 2009 Its deff one to bookmark ;) 1 Quote Link to comment
murderwagon Posted November 7, 2009 Report Share Posted November 7, 2009 has em for 3.99 a piece just replaced them all a week ago on the red dragon 1 Quote Link to comment
Jester Posted November 7, 2009 Report Share Posted November 7, 2009 The VW section at the local yard had them on sale too. :D 1 Quote Link to comment
Xnke Posted November 30, 2009 Report Share Posted November 30, 2009 Another good source is mitsu's...the 4G64 motor has clips that fit, and don't have the little wire retainer, but instead have thumb clips. No wire to loose! 1 Quote Link to comment
I'm BLUE Posted December 16, 2009 Report Share Posted December 16, 2009 Not too surprising about the quality , but very good to know where they came from :-) Thanks ! 1 Quote Link to comment
FricFrac Posted October 31, 2010 Report Share Posted October 31, 2010 Here is another source for the connector/pins/waterproof plugs. I've used these and they are very good quality. Doesn't come with a boot. I used a meltable inner wall heat shrink that stays pretty flexible - works great. http://www.bmotorsports.com/shop/product_info.php/products_id/1644 1 Quote Link to comment
DemonZ Posted February 2, 2011 Report Share Posted February 2, 2011 Thought I'd chime in since I'm replacing mine atm. My local Autozone didnt come up with the 077926 number, just checked their site, and it's not coming up either. However they do carry The GP Sorenson part number 800-9213 for $9.99 each. They had between 1 and 3 in stock at each of the stores in Austin. For those of yall in the Central and Eastern US, Advance Auto Parts no longer carries GP, but they do carry BWD. I did some cross referencing using one of their computers (I used to work there some time ago) and came up with the BWD number. The BWD number is 28419A. However, they were $14.99 each, and had to be ordered from a local warehouse. 1 Quote Link to comment
ggzilla Posted February 2, 2011 Report Share Posted February 2, 2011 Anybody got a tip for how do you get them on and off without breaking them? 1 Quote Link to comment
Skib Posted February 2, 2011 Author Report Share Posted February 2, 2011 Anybody got a tip for how do you get them on and off without breaking them? the stock ones? cuz the new ones just have push clips on them 1 Quote Link to comment
ggzilla Posted February 2, 2011 Report Share Posted February 2, 2011 Yes, the stock ones. They have little wire clips on them similar to the new GM and Audi connectors shown here. Most of mine have broken plastic from trying to get them off. 1 Quote Link to comment
Skib Posted February 2, 2011 Author Report Share Posted February 2, 2011 Most of mine have broken plastic from trying to get them off. yup and thats exactly why i posted this. doesnt happen with the push clips gotta use two tiny screw drivers or picks and the clip wraps around almost all the way and you just have to pull the ends up and pop it off. PITA not to break em. Quote Link to comment
Z-train Posted February 2, 2011 Report Share Posted February 2, 2011 FYI-Bosch injectors have polarity. Quote Link to comment
darrel Posted April 9, 2013 Report Share Posted April 9, 2013 Saab has the connectors as well. quick connect. Their brake system also has a 7 pin connector for the turbo AFM. The boots are in much better shape. but you can check the pliability when you find them. I am sure there are other connectors on the saab for the 3 pin and 5 pin(?) non turbo. Quote Link to comment
JettBear22 Posted October 23, 2014 Report Share Posted October 23, 2014 If you're on a budget Delcity.net has just the standard connectors for only $1.31 Each!! They are just the standard ones and don't come with a boot to cover it. But if someone knows where to get some boots for cheap these ones seem to be the best deal out there! Delcity.net and just look up "fuel injector" Quote Link to comment
