Nissan_Boy85 Posted July 8, 2009 Report Share Posted July 8, 2009 Hydrolock or blown head gasket? Quote Link to comment
datzenmike Posted July 8, 2009 Report Share Posted July 8, 2009 (edited) If it was the head gasket you would see water running down the outside of the block just above the transmission. I assume the water is running out in the general area of the bottom of where the engine and tranny bolt together? It could be from a leaky core plug about 2 1/2 " above the rear of the crank. The water will run down behind the flywheel and out. It's the larger round plug in the picture. The one just to the lower right plugs the oil gallery. http://i138.photobucket.com/albums/q251/datzenmike/Tranny/motorZ24crankauto.jpg[/img]"] JUST NOTICED THIS IS A KA MOTOR. PROBABLY THE SAME AS OR SIMILAR TO THE PICTURE. Edited July 8, 2009 by datzenmike Quote Link to comment
Nissan_Boy85 Posted July 9, 2009 Author Report Share Posted July 9, 2009 (edited) It is literally running out from the crank seal in the rear of the block. UPDATE: Motor does turn, was told it does not start. Still concerned about the "water" coming from the crank seal. UPDATE 2: Just drained the oil pan, got a quart or two of water then about a quart of some milkshake lookin shit. Edited July 9, 2009 by Nissan_Boy85 Quote Link to comment
banzai510(hainz) Posted July 9, 2009 Report Share Posted July 9, 2009 if water by the trans I would think Mike showed you where the freezeplug is at. Maybe thats bad If water in oil could be head gasket or behined the water pump could be a hole in front cover. remove water pump and see if it looked like termites went thru it. Pitted. Runninf not antifrezze will do this or old antifreeze Quote Link to comment
datzenmike Posted July 9, 2009 Report Share Posted July 9, 2009 The rear crank seal keeps the oil in... should keep water out. If the freeze plug is leaking in the picture it shouldn't be able to get into the oil pan. That much water inside... I'm inclined to think like Hainz. Has this motor been stored outside without being covered or air cleaner off??? Seen lots that get rained on and fill up like that. Seen more that freeze and crack the block, timing cover or pop freeze plugs. Have pulled pans only to find a huge rusty 'bathtub ring' of RUST along the crank throws and side of the block. Such a waste. Quote Link to comment
