coolioni Posted July 8, 2009 Report Share Posted July 8, 2009 I have a 1983 720 series pickup with a 2.4 liter engine that was bulit in 4/83. I changed the carb to a weber, so the old air filer is gone. I was looking all over for a fuel filer and could not find one anywhere, so I figured it may have went with the old carb and air filter assembly ? So I just put a new filter inline on the fuel line just before it gets to the carb. Am I just overlooking where the factory fuel filter is located on my truck ? If anyone kows please try to explain where it is located. Thanks! Quote Link to comment
izzo Posted July 8, 2009 Report Share Posted July 8, 2009 on my 720 it is right be the gas tank, below the gas filler neck i can take a pic if you need, it was super dirty and caked with dirt and i almost didnt see it either till i cleaned in there :D Quote Link to comment
datzenmike Posted July 9, 2009 Report Share Posted July 9, 2009 The inline fuel filter (pt # 16400 06W00) is between the fuel tank and the electric fuel pump which is bolted to the outside of the right rear frame just forward of the rear wheel. The electric fuel pump has a twist off bottom cover and a removable/replaceable filter. (Pt # 16404 28530) Quote Link to comment
RatRod25 Posted July 9, 2009 Report Share Posted July 9, 2009 My 84 has two? I dono why.. But my fuel pump is located on the frame.. I have a filter inbetween the tank and pump then the is a filter attached to pump its self like on the bottom unscrews.. Quote Link to comment
coolioni Posted July 9, 2009 Author Report Share Posted July 9, 2009 Can someone take some pics and show me exctly where they are at ? That would really help. Quote Link to comment
deafbob Posted July 15, 2009 Report Share Posted July 15, 2009 you will need to remove the cover, there will be three 10mm bolt holding it. Quote Link to comment
datzenmike Posted July 15, 2009 Report Share Posted July 15, 2009 Bob, good to 'see' you. Quote Link to comment
RatRod25 Posted July 17, 2009 Report Share Posted July 17, 2009 At the bottom of the pump there is a nut, unscrew that and there is a cartridge type filter... And in the upper left hand corner there is a inline type filter.. Quote Link to comment
deafbob Posted July 17, 2009 Report Share Posted July 17, 2009 is there a filter inside the fuel pump?? didn't know that Quote Link to comment
coolioni Posted July 17, 2009 Author Report Share Posted July 17, 2009 i already took care of it. man what a difference. the engine runs so much smoother and has alot more power. the old one must have been so old ! thanks for the help! Quote Link to comment
