Gaskets for F4W71B Transmission
Just wondering if anyone has part numbers or knows where I can get gaskets and seals for this transmission. Its out of a 75 620 as far as I know, (its in my 68). I'm currently having it overhauled, and the guy doing the work cant seem to find the seals. I hit up the local parts place, and they could only reference the input and output seals. I still need a pan gasket, tailhousing gasket and a front release bearing cover gasket.
  • Replies 7
The mechanic working on it got me a part # off of the synchro ring that needed replacing (32605-P0100). I brought that # to the dealership, and he referenced it to the F4W71B transmission. so HOPEFULLY my synchro ring is right at least, since that # came off the part itself. Perhaps the tranmissions used the same synchro rings?
The truck is a 68, but someone had nogged in an Lseries motor and this trans.
uggh what a mess.
Edited by MindlissMetalfab
Yep F4W63, it's why I asked about the pan. The cork gasket for a '68 with L motor is 32162 14810. This is the same gasket used on the 510 4spd.
There is no 32605 P0100 but there is a 32604 P0100 balk ring used on your tranny and also the F4W71B and the FS5W71B 5spd.
Edited by datzenmike
Yeah I hit the 5 by accident. The part I got is the 32604 P0100.
The rear seal I got ended up being right, and I got the size number off the front seal yesterday. I also found the full list of part #s and diagrams on http://www.olddatsuns.com/620tech. So hopefully I can find the rest of the parts i need!
Thanks guys, this forum is definitely a good one!
.... I hit up the local parts place, and they could only reference the input and output seals. I still need a pan gasket, tailhousing gasket and a front release bearing cover gasket.
Rear extension housing gasket:
32134 14600 or 32134 14810 both fit.
Front cover gasket:
32112 14600 or 32112 14810 either fit.
Front cover seal:
32113 14601 original seal
32113 N2100
32113 N2101 this is the latest up-graded seal.
Rear tail stock extension seal:
32136 07200
