What did you do to your dime today?
Mesh-71
  • Replies 4.3k
i sung berry white my first my last my every thing to my dime today while doing a 100 up i5
U tryin to seduce the Dime? DOn't seduce the dime. No means NO!
-Brian
Well I pulled the fuse panel last night and let it soak overnight in vinegar, scrubbed it clean this morning and reinstalled it, cleaned a few connections and replaced a few bulbs, and I got the lights working, everything but the high beams, but I was so happy that everything else was working I decided that was enough electrical for one day. :P So I cut down a backing plate for the su air cleaner, cut it to a size to fit an 80's subie filter.... easier to come by, also cut down the acrylic that the carbs p/o used as an air cleaner top, it is not the prettiest but fully functional until I can afford something better, cant beat the price though! 8 bucks for a new filter :D
HI - I got a 72 dime, been a racecar since new. this is the stuff i did in the last week.
1, took out 5.12:1 R180, it felt funny - it was junk.
2, rear wheel cyls looked original, put new ones in and bled the system - i hate drum brakes too
3, ordered 4.88 geared R180 from a private guy
4, took the motor out, i didn't trust the rod bolts, tore motor down
5, sent rods for re-sizing, arp bolts (rods were ovaled .002")
6, ordered new steel comp retainers, the Alum ones looked beat.
7, installed Holley red pump in place of Carter
8, thinking about setting up a cot in the garage
9, recieved 4.38 geared R180 MF@&$^$*!!!!
10, can't find proper head gasket locally, ordered one from Rallye/sport (add to the retainer order). while i was on the phone, ordered 12:1 Venolia pitsons, pins, teflon retainers, total seal rings
11, maybe one of those bar fridges would be a good idea for the garage?
12, installed the diff - theres just no dealing with some people.
13, started installing a 2nd holley red pump (redundant system)
14, ordered a bunch of #6 AN fittings
15, maybe a TV would be a good idea out there as well?
16, rods are done, motor goes together
17, picked up gaskets and redline 40wt racing oil
18, installed Motorsport Innovations digital EGT
19, i think i'm gonna tell the wife after the races...
20, Calling around for a master cylinder
21, CC'd cyl head and worked out comp ratio: 10.01:1, not bad.
22, dismantled front cover, oil pump, cleaned and painted
23, i need help.
Edited by RoadRace
added text, clarification
23, i need help.
Where are the pics?
pics of the new suite i'm making in the garage?
just kidding!
haven't had any time to take pics - probably the furthest thing from my mind at the moment. i'll snap a few because thats the easy part - posting them requires time...right now i'm just venting because i'm at work and got so much to do at home, like get the motor in the car and fire it up and get it loaded to go racing tomorrow after work. I don't want to be here right now...
last one i bought was $130 (from vancouver) i got this one for $78 US so it'll be less money. but as far a local, nobody wants to get what you what YOU want, they want to sell you what THEY want. the dealership did not call me back after 2 days of calling them. $40 is real cheap - almost too cheap...
Is this a special thickness gasket???????
Felpro Headgaskets are fairly EZ to get. under 30$ look at Rockauto.com
Victor Renz from NAPA also.
importedcarparts.com
Lordco out of Canada.
Or Contact Byron510 on here or the 510realm as he live in Vancouver area.
nissanparts.cc ,superceeded L20 gasket which is 85mm used for the L16/18/20
http://www.nissanparts.cc/cart/?pn=11044-u0804
Unless this is a special gasket this is usually a common part. Most might not have them ready in stock in every store but should have parts in a day or so.
as these special gaskets
http://www.zccjdm.com/catalog.php/azcarbum/dt75036/pd1847029/DATSUN_L4_COPPER_HEADGASKETS_
Edited by banzai510(hainz)
Got my air cleaner finished and mounted, the lights still have a few bugs, but I think I have figured out the problems, now just to fix them, hopefully it will be tagged and on the road by next week, Woot !! I can't fuckin wait :D:D
Got the plugs I needed. Wired it up. 1 injector was leaking like a sieve. Luckily, I snagged some spares at the JY todays while I as getting my plugs. Fxed that and attampted to start it. Turns over kinda. Think my battery needs a charge.
i used a V/renz gasket once and the car over heated almost immediately - took a while to burp it. i have been told by a few people who race to never use anything but the OEM gasket, i have done that and had no problems. i don't think its special or anything, the aftermarket ones are just cut-rate and don't meet the same spec as the OE one.
