stock bodied 510 upper rear wheel well remodel
datsundan
  • Replies 3
Most people call it a "mini-tub." Judging by your avatar, you have a 2 door. Here's a few pictures from Dillon's build thread:
Basically, you cut the outermost portion of the wheel well that connects to the quarter panel, and weld a straight sheet in its place to give yourself some extra clearance.
Do a search for "mini tub" on here and it'll pop up a few hits.
The rear quarter can be rolled/pulled. Take a dowel, bat, or something cylinder that can fit between the tire and quarter. Get another person and after heating up the quarter around the areas you are going to be bending have the other person drive forward (very very slow) while you guide the object you are using around the quarter lip. Do this a few times gradually applying more pressure until you reach the clearance you need.
-Colton
Edited by cjr198car
