slinginabullet Posted July 1, 2009 Report Share Posted July 1, 2009 Stick with a L 16, 18 or 20. Most swaps dont get finished & the truck will sit. True but if you really want it you can make it happen I did my swap in about a month from tear down to drivin. With my kids in my way lol and about 600 bucks includes moter trany new exhaust the works just can't expect not to bleed a little 1 Quote Link to comment
Zephyr620 Posted August 20, 2016 Report Share Posted August 20, 2016 ok. thanks =] i just got lazy coz i was using my phone. for that rolla.. 4agze 4age 20v 4age 16v 13b =] f20 just to name a few . KA24E Does not 'bolt on'. Needs a KA or Z24 tranny, EFI wiring and all sensors and a high pressure fuel pump at the least. Weighs about 100 lb more than an L20B. L28 Does not 'drop in'. Too long. Firewall needs to be cut out thus loosing the heater and needing sheet metal mods or move rad to the box and stick the front two cylinders out behind the grill. This motor weighs a ton and will fuck up the handling. SR20DET Expect as much work as the KA but with the added plumbing problems of the turbo around the steering column and the torsion bars. L16/18/20B Yes they bolt in and fit the stock tranny. Must have a truck oil pan. This idea is just out of convenience, but fuzzy, with your yota exp. do you think a 4agze could go in a 73 620? Also asking your opinion Mike :) Thanks guys sorry i know this is a very old post. 1 Quote Link to comment
datzenmike Posted August 20, 2016 Report Share Posted August 20, 2016 Had to look up what 4agze is. Does it have a RWD transmission for it? Then yes it could be fitted. Engine mounts, rad, exhaust, trans mount, oil pan clearance, electronics, fuel pump would all need to be addressed but just about any 4 cylinder will work in the 620. 1 Quote Link to comment
Farmer Posted August 21, 2016 Report Share Posted August 21, 2016 Wow, a 7 year old thread gets resurrected. Had to re read it to find out what it contains 2 Quote Link to comment
datzenmike Posted August 21, 2016 Report Share Posted August 21, 2016 Best fit is the same year L engine, next best any other year L or LZ series engine. Then KA as they are the most documented. Then just about any other in line 4 cylinder. Then V6s. There are one or two small V8s but the title says fit and if you have to cut the firewall... that's not a fit. 1 Quote Link to comment
gene knight Posted August 24, 2016 Report Share Posted August 24, 2016 Guest_DatsuNoob_* : just put in a Toyota 2JZ motor in the corolla Quote Link to comment
G-Duax Posted August 24, 2016 Report Share Posted August 24, 2016 I would rather have the stock L18, than a '4AGee I have no torgue' smog engine. 1 Quote Link to comment
8m0untainman8 Posted January 3, 2017 Report Share Posted January 3, 2017 I like this thread, it has some interesting info. Ive been considering pulling a ford 4.0l out of something and doing this, Honestly didnt think it would have been done already. Quote Link to comment
Lorenzo 33 Posted April 1, 2022 Report Share Posted April 1, 2022 Why hasn't anyone thought about a chevy ecotec? Dohc, VVT, low end torque, great mid range, by the time you reach the top end when the motor falls off, the race is over. Me personally I race open wheel buggies and we run these motors, of course they are built a bit (rods, JE-pistons and aftermarket oil and plumbing mods is all) but they last long, sound good, get good mpg, and can hold easily around 500 to 800 as I've been told. We run a spec class so the motors are all built, tagged, tuned, and dynoed by the same guy. We push 180 NA on the 2.4l. I honestly wanted to swap my L20b out for this and find a trans for it etc. I think a stand alone wire harness is about 400 bucks. We put these in completely custom buggies so all it needs is basic computer stuff and shouldn't interfere with the dash and such aside from gauges. I saw someone got about 1,100 hp out of a fat turbo setup in a Jr. Dragster. So a decent turbo or even NA would be tons of fun. 1 Quote Link to comment
EDM620 Posted April 4, 2022 Report Share Posted April 4, 2022 On 4/1/2022 at 2:56 AM, Lorenzo 33 said: chevy ecotec? Maybe anti-bow tie bias? LOL Quote Link to comment
7twentyguy Posted May 9, 2022 Report Share Posted May 9, 2022 I rented a 2.3 eco boost Mustang last week, I drove it like a rental! I tried all of the go fast goodies, S mode, line lock … damn thing was kinda fun, has anyone successfully swapped one of these into a Datsun/Nissan? If I ever win the lottery I’d stuff one in my 720. I know, that’s cross breeding! But I’m dreaming anyway! Quote Link to comment
