uhhitsfuzzy Posted June 30, 2009 Report Share Posted June 30, 2009 (edited) im talking about bolt ons and the ones that requires not so many fabrications. so far.. ka24e L28 sr20det L16 L18 L20B more? Edited June 30, 2009 by uhhitsfuzzy 1 Quote Link to comment
Skib Posted June 30, 2009 Report Share Posted June 30, 2009 an L28 fits in a 620 with little or no modification? what about adding all the L4 motors to your list lol 2 Quote Link to comment
Guest DatsuNoob Posted June 30, 2009 Report Share Posted June 30, 2009 search! :D:D read Jeff's (Icehouse) writeup, or look into a frontier motor if you want dual cam. Quote Link to comment
ggzilla Posted June 30, 2009 Report Share Posted June 30, 2009 Have pity on him. The ones that bolt in: L16, L18, L20B. 1 Quote Link to comment
uhhitsfuzzy Posted June 30, 2009 Author Report Share Posted June 30, 2009 hahaha sorry guys im still a noob when it comes to datsun. i went from acuras to corollas to z then my 620. 1 Quote Link to comment
Guest DatsuNoob Posted June 30, 2009 Report Share Posted June 30, 2009 That's cool, we all gotta start somewhere. I just mean that you may be able to answer your own ? in the future by searching all the great info from past threads. So, Toyota guy.... what motor can I put in my granny corolla to make a go-fast granny corolla?:lol::lol: I know nothing of them, but the fact that I've put nearly 50k on a $500 car with a stock 1.6L. Quote Link to comment
uhhitsfuzzy Posted June 30, 2009 Author Report Share Posted June 30, 2009 ok. thanks =] i just got lazy coz i was using my phone. for that rolla.. 4agze 4age 20v 4age 16v 13b =] f20 just to name a few . 1 Quote Link to comment
Skib Posted June 30, 2009 Report Share Posted June 30, 2009 correct me if Im wrong but I dont see an L28 fitting in with ease, if it did Im sure someone here would be rockin an L28et 620 by now. 1 Quote Link to comment
LCDC Posted June 30, 2009 Report Share Posted June 30, 2009 correct me if Im wrong but I dont see an L28 fitting in with ease, if it did Im sure someone here would be rockin an L28et 620 by now. ask steroid, I bet he has a picture somewhere of a 620 with the nose extended to fit a L28 in it. I've seen the pic 1 Quote Link to comment
Skib Posted June 30, 2009 Report Share Posted June 30, 2009 iv seen it done on a 510 but i just dont see it being easy lol, he was asking about swaps that bolt in or dont req much fabrication 1 Quote Link to comment
Pacific coast Datsun Posted June 30, 2009 Report Share Posted June 30, 2009 Stick with a L 16, 18 or 20. Most swaps dont get finished & the truck will sit. 1 Quote Link to comment
datzenmike Posted June 30, 2009 Report Share Posted June 30, 2009 im talking about bolt ons and the ones that requires not so many fabrications. so far.. ka24e L28 sr20det L16 L18 L20B more? KA24E Does not 'bolt on'. Needs a KA or Z24 tranny, EFI wiring and all sensors and a high pressure fuel pump at the least. Weighs about 100 lb more than an L20B. L28 Does not 'drop in'. Too long. Firewall needs to be cut out thus loosing the heater and needing sheet metal mods or move rad to the box and stick the front two cylinders out behind the grill. This motor weighs a ton and will fuck up the handling. SR20DET Expect as much work as the KA but with the added plumbing problems of the turbo around the steering column and the torsion bars. L16/18/20B Yes they bolt in and fit the stock tranny. Must have a truck oil pan. 1 Quote Link to comment
Llittle_Llama Posted June 30, 2009 Report Share Posted June 30, 2009 Stick with a L 16, 18 or 20. Most swaps dont get finished & the truck will sit. look on craigs list......thats where all the projects that sat for years go.... 1 Quote Link to comment
4.0lratsun Posted June 30, 2009 Report Share Posted June 30, 2009 ya i started an l28 swap back on my first 620 to get around the high strung l20 that was in it gave up and bought a 73 240z to put it in back to the point the ford ranger ohv 4.0l goes in with out to much work it was alot easier than i anticipated 1 Quote Link to comment
Llittle_Llama Posted June 30, 2009 Report Share Posted June 30, 2009 you have GOT to post pics, that motor is pretty low HP wise, but the TQ is DEFINITELY there!!! nice motor. 2 Quote Link to comment
uhhitsfuzzy Posted June 30, 2009 Author Report Share Posted June 30, 2009 ya i started an l28 swap back on my first 620 to get around the high strung l20 that was in it gave up and bought a 73 240z to put it in back to the point the ford ranger ohv 4.0l goes in with out to much work it was alot easier than i anticipated pics pls! 1 Quote Link to comment
BEEBANI Posted June 30, 2009 Report Share Posted June 30, 2009 100lbs. Mike? are you sure about that? The L20 and the ka use almost indentical blocks. My ka was almost a drop in affair. I'm currently working on some brackets for the ka that will allow guys to drop it onto the stock 620 rubber mounts. I can do the harness rework in about 5 hours also with all new relays. Power to weight ratio is rediculous in these trucks with that motor. The problem with the L28 is weight, length, power, and aftermarket. Even the 24E has a lot of options for power adders. The ka's are also easy and cheap to come by with all the 240 guys doing the sr swap. That's my .02. 1 Quote Link to comment
Skib Posted June 30, 2009 Report Share Posted June 30, 2009 theres quite a bit of after market for the L6 actually. dosent seem practical for a 620 swap tho lol. Id just toss in an SR and make more than enough power instead of trying to shoehorn an L6 in. 1 Quote Link to comment
BEEBANI Posted June 30, 2009 Report Share Posted June 30, 2009 theres quite a bit of after market for the L6 actually. dosent seem practical for a 620 swap tho lol. Id just toss in an SR and make more than enough power instead of trying to shoehorn an L6 in. Yeah, I'm just sayin, L6 stock vs. a ka24 isn't worth the trouble. Turbo'd or pumped up might be, but still a lot of work to fit it in there. I wanna do a ka-T! 1 Quote Link to comment
Skib Posted June 30, 2009 Report Share Posted June 30, 2009 Yeah, I'm just sayin, L6 stock vs. a ka24 isn't worth the trouble. Turbo'd or pumped up might be, but still a lot of work to fit it in there. I wanna do a ka-T! lol ya it wouldnt be worth the trouble of just getting one in there when you can get plenty of power from a KA or SR and they already fit 1 Quote Link to comment
datzenmike Posted July 1, 2009 Report Share Posted July 1, 2009 100lbs. Mike? are you sure about that? The L20 and the ka use almost indentical blocks. They are similar but that's it. They would have a larger crank and if you look where the block mates to the tranny there is a lot more metal there. It's also wider through the block at the crank. The KA24DE is about 370 without oil and coolant.The E can't be that much less. The L20B is about 260. 1 Quote Link to comment
Llittle_Llama Posted July 1, 2009 Report Share Posted July 1, 2009 hey bee, any idea on the cost of the parts to do the swap? 1 Quote Link to comment
ggzilla Posted July 1, 2009 Report Share Posted July 1, 2009 (edited) RE: 4.0 liter Ford V6 in a Datsun 620... I'm sure it is typical conversion swap (custom driveshaft, engine mounts, exhaust etc.). But I would expect a 5.0 liter V8 would be even easier. They even fit em into tiny Datsun 1200s where Ford 2.8 V6 will not fit. Edited July 1, 2009 by ggzilla 1 Quote Link to comment
datzenmike Posted July 1, 2009 Report Share Posted July 1, 2009 What does the Ford 4.0 weigh? The VG is 390? well under 400 lbs. 1 Quote Link to comment
ggzilla Posted July 1, 2009 Report Share Posted July 1, 2009 A have a list which says: * Ford SHO 3.0 V6: 465 pounds * Ford 4.2 V6: 488 pounds * Ford 302 with iron heads: 450 pounds * Ford 5.0 with alumi heads: 411 pounds 1 Quote Link to comment
