Datsun fan Posted June 27, 2009 Report Share Posted June 27, 2009 OK, each time I shut my A15 engine off I watch the carb ( stock Hitachi ) & fuel level ( glass magic eye ) will go down slowly , after about 2 hours there isn't almost any fuel there , starting engine after 3-4 days will take about 5 tries to get that pig started !!!!!!! is this normal ??? is it a faulty one-way fuel valve ??? or is it just the fuel ( evaporation ) from ther carb cos engine is warm ??? anyway the fuel tank is LOWER than stock about 20 inches , no gas leak . Any ideas ................ Quote Link to comment
ggzilla Posted June 27, 2009 Report Share Posted June 27, 2009 Yes, it is a common problem. But it can be fixed. Most commonly the main jet gaskets are leaking. Just take the nut guard off and tighten them a bit. Probably does not need new gaskets. Here's my own A-series carburetor before and after leaking: Hitachi DCH-306 leaking fuel at main jet plug gasket Quote Link to comment
Datsun fan Posted June 27, 2009 Author Report Share Posted June 27, 2009 First thank you ggzill for the ultra super fast post . can I extract from your post that descending fuel level I have is abnormal ??? I carried out visual check of that thing and found no leaks . What is the next step ?? Quote Link to comment
ggzilla Posted June 27, 2009 Report Share Posted June 27, 2009 It is normal on a 30 year old vehicle. But when new it was a new Datsun it would have been considered Abnormal. With my carburetor I could not observe fuel running out or leaking. Just the fact that it was wet and dirty was the indication. After i tightened those plugs it can sit for a couple of weeks before draining completely. Quote Link to comment
Datsun fan Posted June 27, 2009 Author Report Share Posted June 27, 2009 Hmmmmmm , I will tighten these things and test the leak again What about one-way fuel valve ??? is it integrated in the fuel pump as I think ?? How to test that valve ???? the return line is NOT connected at all to the pump . Anyway, could you pls let me know what the return line is made for ?? Quote Link to comment
ggzilla Posted June 27, 2009 Report Share Posted June 27, 2009 (edited) The fuel pump and fuel line have nothing to do with Carburetor fuel bowl ascending level. Datsun B310 (150Y) has a fuel return line, but whether connected or not has nothing to do with this problem. Most other Datsuns have a fuel tank vent line, not a return line. The fuel level descending is caused by leak internal to the carburetor. Even if you remove fuel pump, the carburetor should still hold fuel in the bowl for a at least a couple of days. But ... perhaps someone from California or Arizona can comment on how high heat (above 100F/38C) affect evaporation. I am pretty sure that it should last longer than 2 hours, as I have driven my Datsun in those temperatures once or twice and not notice any problem. Edited June 27, 2009 by ggzilla Quote Link to comment
hang_510 Posted June 30, 2009 Report Share Posted June 30, 2009 But ... perhaps someone from California or Arizona can comment on how high heat (above 100F/38C) affect evaporation. I am pretty sure that it should last longer than 2 hours, as I have driven my Datsun in those temperatures once or twice and not notice any problem. significantly. in the 3-4 days of not driving, yeah itd be empty. if my 4dr sat (weber) for a week or so, the bowls were empty. electric fuel pump allowed it to fill faster so i didnt have to crank it until they were filled. Quote Link to comment
ggzilla Posted July 1, 2009 Report Share Posted July 1, 2009 Thanks. So this did not happen in winter, when temperature was 80 degrees or lower? Quote Link to comment
Datsun fan Posted July 3, 2009 Author Report Share Posted July 3, 2009 3 or 4 days ??!!! I'm talkin about 2 hours!!!!! The bottom line ............ is it evaporation or leaking gasket you guys think??? Quote Link to comment
72240z Posted July 3, 2009 Report Share Posted July 3, 2009 Would take longer then 2 hours to evaporate. I'm voting leak. Quote Link to comment
