5casey1dimer0 Posted June 26, 2009 Report Share Posted June 26, 2009 Well I'm stuck at home bored for a few more hours, and feel like workin on the car. A while back i was lookin at joe's (zuum510) old green 510 and he was tellin me about how he wired up the tail lights so when the brakes were pressed the entire light lit up, not just the inner half of the light. Or maybe when the lights were on, the entire light lit up. He said it was an old trick not too many of the younger guys do anymore. I was wondering if any of you knew how to do this and could give me a real quick walk through. thanks Quote Link to comment
NorCalDime Posted June 26, 2009 Report Share Posted June 26, 2009 like this? [/img] Quote Link to comment
5casey1dimer0 Posted June 26, 2009 Author Report Share Posted June 26, 2009 Yes! Just like that! Quote Link to comment
5casey1dimer0 Posted June 26, 2009 Author Report Share Posted June 26, 2009 Anybody? NorCalDime is teasin me now with his reply.... Quote Link to comment
WagDatto Posted June 26, 2009 Report Share Posted June 26, 2009 Well with the wagons, we have a small metal "splitter" piece that slides into the light housing (just behind the lens). I'd assume you pop off the lens, remove that bit, put lens back on. Could be wrong, I'll tell Chris (NorCalDime) he needs to update the thread tonight. Quote Link to comment
qwik510 Posted June 27, 2009 Report Share Posted June 27, 2009 Volume 4.3 of the Dime Quarterly has an article on how it is done Quote Link to comment
5casey1dimer0 Posted June 27, 2009 Author Report Share Posted June 27, 2009 Thanks guys, ill check into the dimequarterly, but it would still be great if chris can help me out. Quote Link to comment
rzrdisco Posted June 27, 2009 Report Share Posted June 27, 2009 Well with the wagons, we have a small metal "splitter" piece that slides into the light housing (just behind the lens). I'd assume you pop off the lens, remove that bit, put lens back on. Could be wrong, I'll tell Chris (NorCalDime) he needs to update the thread tonight. that is somewhat of a fix but doesn't really work 100% because the brake lights will bleed through and prevent his blinker from working. what he wants (i think) is to have the brake lights overtake both bulbs but when he uses his blinker then the blinker bulb will terminate the brake light and act as a blinker. eh but maybe not. Quote Link to comment
banzai510(hainz) Posted June 27, 2009 Report Share Posted June 27, 2009 cops might not like it. My yellow 510, the amber are ON all the time With lights On and do work with the turnsignalas supposed to. He was looking for soemthing and he found it I got pulled over!!!!!!!!!!!!!! Quote Link to comment
qwik510 Posted June 27, 2009 Report Share Posted June 27, 2009 The basic jist of the conversion is that you need to get 2 more dual filament bulbs holders. Use one on each side to replace the existing outer single filament bulb holder and tap into the running light and brake light wiring from the inner holder so it activates the new outer one and also hook up the turn signal wire to the 2nd filament. The DQ article has the wire colors and exact description of how to do it. Quote Link to comment
5casey1dimer0 Posted June 28, 2009 Author Report Share Posted June 28, 2009 (edited) thanks guys, i think i get it, ill give it a shot. And thanks for the heads up about the cops, i doubt ill get bothered for it, and if i do, ill just play dumb and say i thought thats how it was factory, and ill look into fixing it:fu: Any other help is still appreciated:) Edited June 28, 2009 by 5casey1dimer0 Quote Link to comment
fastdadd Posted June 28, 2009 Report Share Posted June 28, 2009 i am going to do it to my truck inthe morning i will take pics and let you know Quote Link to comment
5casey1dimer0 Posted June 28, 2009 Author Report Share Posted June 28, 2009 i am going to do it to my truck inthe morning i will take pics and let you know cool thanks! I'll check them out as soon as im off work. Quote Link to comment
Byron510 Posted June 28, 2009 Report Share Posted June 28, 2009 I did a similar thing with both of my rally cars - using another dual filament plug robbed from another 510 tail light harness, however I had all four lower wattage lights hooked up to the running lights, but left the inner high wattage filaments for brakes, the outer high wattage filaments for signals. The extra two running lights really increases the visibility from the rear of the car at night Quote Link to comment
qwik510 Posted June 28, 2009 Report Share Posted June 28, 2009 I did a similar thing with both of my rally cars - using another dual filament plug robbed from another 510 tail light harness, however I had all four lower wattage lights hooked up to the running lights, but left the inner high wattage filaments for brakes, the outer high wattage filaments for signals. The extra two running lights really increases the visibility from the rear of the car at night Quote Link to comment
fastdadd Posted June 28, 2009 Report Share Posted June 28, 2009 it did not get done today i had some stuff come up Quote Link to comment
5casey1dimer0 Posted June 28, 2009 Author Report Share Posted June 28, 2009 thanks for all the input, thanks for the heads up too fastdadd. im looking forward to your pictures soon:D Quote Link to comment
