g-mam Posted June 26, 2009 Report Share Posted June 26, 2009 My charge light is on when at idle, but as soon as I rev it goes out. is there something I could have knocked loose while replacing the Master cylinder? I never noticed it before. I'm sure it just started. Quote Link to comment
uhhitsfuzzy Posted June 26, 2009 Report Share Posted June 26, 2009 i have the same thing i just havent ask what it was. thanks for bringing it up Quote Link to comment
banzai510(hainz) Posted June 26, 2009 Report Share Posted June 26, 2009 its usaully the brushes in the alternator but you could put a volt meter on the battery while its running to tell us what you read. If reads above 15volts I say the volt reg. But I go with my first post of the Alternator bad. One of my brushes was worn out(short and when you really rev the car assume the slip ring had enough outward movement to tought the brush. Then the light went OUT Also try cleaning the battery post and maybe moving or cleaning the fuse ends at the fuse box not hat would fix it. By the time a charge lite comes on something is really BAD Quote Link to comment
datzenmike Posted June 26, 2009 Report Share Posted June 26, 2009 Oil leaking on the alternator??? from the timing cover or the fuel pump??? Quote Link to comment
g-mam Posted June 26, 2009 Author Report Share Posted June 26, 2009 I just took it to the car wash to clean the engine compartment. About a 5 mile trip each way. Still runs like crap! But the light went off and is now staying off. Maybe just dirty or stuck brushes. Local battery shop quoted me a new one for $80 installed if I need it. I gotta figure out that carb! Quote Link to comment
ggzilla Posted June 27, 2009 Report Share Posted June 27, 2009 $80 ? They are only $35 at Schucks/Kragen/Grand http://www.oreillyauto.com there web site, ask you local store for price matching. 1974 uses 35A alternator. Quote Link to comment
g-mam Posted June 27, 2009 Author Report Share Posted June 27, 2009 $80 ? They are only $35 at Schucks/Kragen/Grand http://www.oreillyauto.com there web site, ask you local store for price matching. 1974 uses 35A alternator. Remember, that is INSTALLED! Quote Link to comment
ronnny Posted June 27, 2009 Report Share Posted June 27, 2009 I have a 720 the alt light stayed on and i swapped it out with another 720 and it went out. Quote Link to comment
