620mike Posted June 24, 2009 Report Share Posted June 24, 2009 (edited) ok so here is the deal..... i read the write-ups and confused myself, i think i might have made a mistake will some one help me. i bought a DOHC KA24de out of a 93 240sx i got everything with it engine, trans, mounts, wiring harness, ECU, exahust, radatior fans, driveshaft. Did i just bu all this stuff for no reason? from what im reading only the wiring harness will fit. If i didnt make a big mistake can someone tell me what i can do o redirect me somewere:confused::confused::confused::confused: Edited June 24, 2009 by datzenmike Quote Link to comment
Guest DatsuNoob Posted June 24, 2009 Report Share Posted June 24, 2009 The only main issue I see is the steering link (bar that connects pitman and idler arm) may have clearance issues with the oil pan. People say to get the Frontier version since it features a rear sump pan and is supposed to clear just fine, but anything is possible with a little patience, a tape measure, and a welder. You'll have to cut the stock link and add some new material to create a kind of "C-shaped" offset that will get around that pan when you turn the steering wheel. I've seen SR swaps into 620's before (front sump), so it's certainly do-able. You may want to consider an Lseries compatible transmission with a Z-24 bell swap to use the stock driveline and speedometer cable input. Good luck dude Quote Link to comment
620mike Posted June 24, 2009 Author Report Share Posted June 24, 2009 now the oil pans are not inter-changable even though ther the same motor? and could i use the stock trans if need be Quote Link to comment
datzenmike Posted June 24, 2009 Report Share Posted June 24, 2009 (edited) The '93 240sx with KA24DE had a front sump oil pan and an internal oil pump inside the timing cover. The Hardbody KA24E AND later KA24DE truck motors both had a rear sump with an external oil pump just like the L series. The 240sx DE engine with internal pump has a different shaped oil pan at the front right side. This means that the 240sx motor will not accept a E or DE oil pan from a Hardbody or Frontier. I would get a HB or Frontier oil pan AND the oil pick up tube and modify the front to fit the 240sx timing cover. The 240sx is just like the L series and straight across the front. The HB/Frontier has the right side front corner missing like it was trimmed off. Perhaps a flat plate could be added to the HB/Frontier rear sump pan to extend to the 240sx's corner to seal it up. Might be easier than you think. Don't forget the rear sump pick up tube. Edited June 24, 2009 by datzenmike Quote Link to comment
BEEBANI Posted June 24, 2009 Report Share Posted June 24, 2009 And, I will have custom motor mounts that will allow you to drop that motor right in by the end of this week. Stay tuned..... Quote Link to comment
620mike Posted June 24, 2009 Author Report Share Posted June 24, 2009 do you have an estimated price yet Quote Link to comment
BEEBANI Posted June 24, 2009 Report Share Posted June 24, 2009 do you have an estimated price yet I'm thinking $75 for the pair plus shipping. It's the piece that bolts to the block that allows you to use the stock 620 rubber pieces. Quote Link to comment
butcherboyjc Posted June 25, 2009 Report Share Posted June 25, 2009 I flipped the center link on my ka24de 620. Im not on the road yet, still plumbing the fuel lines so I haven't tested the center link yet. I found that some VW drivers and offroaders have flipped their center links with great results. I purchased a tapered reamer from XKUT. http://www.xkut-reamers.com/servlet/StoreFront After flipping it the front sump cleared. Quote Link to comment
620mike Posted June 25, 2009 Author Report Share Posted June 25, 2009 i was actually thinking of building my steering from scratch but that sounds better... its alot to think about so im kinda taking it slow.. Quote Link to comment
