groatd Posted June 23, 2009 Report Share Posted June 23, 2009 my 74 620 with a l18 isnt chocking, i know it does it by heating up the coil in the mechinisum but i dont know how to set it or how to determin if its broke? Quote Link to comment
datzenmike Posted June 23, 2009 Report Share Posted June 23, 2009 There should be 12v on the White/Blue wire going into the choke heater. (but only when motor running) Choke heater should get very warm to the touch. Quote Link to comment
banzai510(hainz) Posted June 23, 2009 Report Share Posted June 23, 2009 (edited) there is 3 screws. you loosen the screw then turn the round canister one way or the other to get the choke open or close. when cold to should be closed and as the car is running it will slowley heat up and the choke plate will start opening. I personally never can get it just right after i fuck with them. Either is running too much choke after I start driving or not enough. So I went with the manula pull cable type. Edited June 23, 2009 by banzai510(hainz) Quote Link to comment
groatd Posted June 23, 2009 Author Report Share Posted June 23, 2009 ya thats what every bodys has been telling me to do, but i wanna try and get this fixed before i start looking like a redneck lol :) Quote Link to comment
groatd Posted June 24, 2009 Author Report Share Posted June 24, 2009 aw ha i got it fixed it thanks a lot u guys :lol: Quote Link to comment
datzenmike Posted June 24, 2009 Report Share Posted June 24, 2009 Loose wire? Stuck linkage? Huh? Quote Link to comment
groatd Posted June 24, 2009 Author Report Share Posted June 24, 2009 the choke coil just wasint set right, so i set it to about 3/4 choke and it runds and drives fine, Quote Link to comment
72wagun Posted June 24, 2009 Report Share Posted June 24, 2009 I was able to get the one on my weber adjusted pretty well after some trial and error. I set it while cold so that the plate was completely closed with barely any tension on the spring (thermal coil thing). Then I let it run until it was completely warmed up. When the thermal coil got all warmed up, the plate is completely verticle. I also ended up bypassing the stock choke relay. Mine was dead, and the closest replacement I could find at the parts store was kind of expensive. The guy at Napa told me that he just hooks them up to the alternator stator wire so that whenever the motor is turning, it sends power to the choke actuator. He said all the V8 hotrod guys do this with their Holleys and Edelbrocks. I searched on several hotrod sites, and found this is common practice. Anyone else done this? Quote Link to comment
banzai510(hainz) Posted June 24, 2009 Report Share Posted June 24, 2009 I seen some wire come off the down side of the ballast resistor o soem 521 going to the bcdd valve on carbs. I wonder if this can be used. I dont care, Mine are manual choke now. Quote Link to comment
72wagun Posted June 24, 2009 Report Share Posted June 24, 2009 I've thought about switching to manual. When it's warm, the choke is on longer than it needs to be. It's annoying having the motor idling high until the choke turns the high idle cam out of the way. I probably need to turn down my high idle screw a little too, but it would be nice to just open the choke when it's not needed. Quote Link to comment
banzai510(hainz) Posted June 24, 2009 Report Share Posted June 24, 2009 the choke is on longer than it needs to be. loosen the the 3 screws and turn it to lessen the choke so it opens the plate sooner. Be honest I could never get it quit right when I has a stock carb. It was too much choke or not ehought where it affected the running of the car(esp at stop light) if not fully warm Quote Link to comment
72wagun Posted June 24, 2009 Report Share Posted June 24, 2009 Yeah, I adjusted it several times, and I think it's about as good as I can get it. I meant that when it's really cold outside, you need the choke on for a little while until the engine gets warm enough, but when it's warm weather the choke doesn't need to be on much if at all. That's why I think the manual is nicer. A person is a smarter than a little coiled up piece of metal. Quote Link to comment
