offset for wilwood brake kit
vegas510
  • Replies 6
depending on the kit (BIG or small rotor) I have his big rotor kit and have fit 15" panasports with a +18 offset with that kit and have seen a few cars at the shop with 13" panasports fit over the small rotor kit as far as offset its using a stock 510 strut and any wheel that fits a stock fendered 510 should fit as long as the inner lip of the wheel clears the top of the caliper you should be good
Clayton
how bad is it hitting? if its rubbing slightly you can sand a little off the caliper with no problems but if it stopping the wheel from turning you may have to find a different wheel :(
