720 Fuel Assembly Replacement
onesixteenth
I was on the freeway today when I had a pretty good blowout with my passenger rear tire. While changing the tire I realized the pieces of rubber from the tire had swung around the wheel well and tore everything to shreds. There's nothing fron the fuel tank to the gas cap door, i.e you open the door and there's a big round hole and you can see straight through to the gas tank.
Pictures.
As you can see I taped up the two openings on the gas tank. What parts do I need to fix this?
  • Replies 4
Filler hose (from tank to Filler tube assy).... # 17228-10W00
Filler tube assy (from filler hose to gas cap) # 17251-U7402
Vent hose (from tank to filler tube assy)..... # 17226-08W00
Gas cap for filler tube assy....................... # 17251-36W00
...and few gear clamps.
